Honda S2000 Honda S2000
Fuel Filter
Old Mar 23, 2010 | 06:23 AM
ExVtec's Avatar
Default Fuel Filter
I was looking on majestichonda.com / hondaautomotiveparts.com and couldn't find the fuel filter...
Whats the story?
Old Mar 23, 2010 | 11:15 AM
camoy's Avatar
Default Re: Fuel Filter
00-05 part number 17516-S2A-930
06+ part number 17516-SDC-E00
Old Mar 24, 2010 | 05:12 AM
ExVtec's Avatar
I saw that, but the description leads me to believe it's the sock on the end of the pump.
I was looking for the filter that mounts in the engine bay.
Old Mar 24, 2010 | 06:09 AM
ExVtec's Avatar
Link to diagram.
http://www.hondaautomotiveparts.com/...gry5=FUEL+TANK
Old Mar 24, 2010 | 06:28 AM
esoterEK..'s Avatar
s2000's have no inline fuel filter....
Old Mar 24, 2010 | 10:57 AM
ExVtec's Avatar
Well it's showing another filter "thingy" in the diagram...that isn't the sock...so I wonder what that is?
Old Mar 25, 2010 | 04:53 AM
ExVtec's Avatar
bumpage.
Old Mar 25, 2010 | 04:56 AM
camoy's Avatar
ok that diagram has a lot of stuff in it could you please tell me what number is near the item you believe to be a fuel filter? I have installed a fuel pump in my car and when I had everything out I didn't see anything that looked like a inline filter.
Old Mar 25, 2010 | 05:03 AM
ExVtec's Avatar
Exactly my point, lol.
Well, #1 and #7 BOTH have similar descriptions.
#7 looks to be the filter sock that attaches to the end of the pump, and #1 is on top of the pump...?
Old Mar 25, 2010 | 05:12 AM
camoy's Avatar
OK yes number 7 is the sock, number 1 is what the pump "plugs" into if you will. There is a hole in the bottom that the fuel pump mounts in. Then the item right below #2 and to the right of #39 is a white clip that is formed in the shap of the bottom of the fuel pump. This clips onto the bottom of #1 and holds the fuel pump in place, now I don't know if #1 is a filter. It could be as the fuel pump plugs into this via a 2in long rubber hose (it is the item between the two #39s), and then the fuel comes out of the top which is the connector you see outside the tank with the quick connect fuel lines. But if it is a filter that is not the only thing that it is, there are a few electrical connections on it too, as well as the fuel level sensor attaches to it. Why do you need to replace this part?
Old Mar 25, 2010 | 10:58 AM
ExVtec's Avatar
I don't have to replace anything, I was just wanting to replace the fuel filter, well...b/c.
It's a car with 50k on the ticker and I am going to be pushing alot of fuel through it over the next month and I want everything on the up & up.
W/that said...this means we do not have a fuel filter aside from the fuel pump sock?
Old Mar 25, 2010 | 11:50 AM
camoy's Avatar
Well if you are taking it out to do install a Walbro 255 fuel pump you will want to do the sock. Seeing as the part is only about 50 bucks you could change it out any way and not worry about any "what ifs". When I had mine out it looked like a mounting assembly with the electrical connections running from the top to the stuff inside like the fuel level sensor and pump power. I can look and see if I took a picture of it when I had it out, as I tend to do that before I take anything apart.
Old Mar 25, 2010 | 11:55 AM
quickster's Avatar
Do you have to get underneath the car to replace a fuel filter? on my car? (see sig)
Old Mar 25, 2010 | 01:27 PM
4doorH22's Avatar
Don't know why you're on this forum, but welcome. No you don't. The 4th gen Accord fuel filter is along the top of the firewall and you can get to it from under the hood.
Old Mar 25, 2010 | 03:04 PM
quickster's Avatar
im on this forum for information. i have not done much maintenance on hondas and so im joining up on here with a ton of questions, thanks for welcoming me and thanks for the info about the filter
Old Mar 26, 2010 | 05:02 AM
ExVtec's Avatar
He means this is an S2000 forum your in ??
There are Accord dedicated forums as well.
Old Mar 28, 2010 | 06:39 PM
ExVtec's Avatar
New week bump.
adam00
Mar 11, 2010 09:31 AM
ExVtec
Honda S2000
Feb 2, 2009 12:12 PM
Agent Zero
Honda S2000
Mar 4, 2008 10:08 PM
IMSTOCK
Jun 21, 2005 06:42 PM
