Honda S2000 Honda S2000
Engine Knocking ???
Old Aug 5, 2005 | 04:53 AM
ranta18's Avatar
Default Engine Knocking ???
Lets run down the possible causes for a knocking noise from a factory F20C engine. Keep in mind the story of ths engine:
The engine was beat on by the original owner, he traded it in and the dealership beat on it hard, then it was sold. Shortly after a rod bearing went. A completely new block was put in by Honda. It was driven hard and then boosted by a Vortech superchager. It was driven hard boosted and not fully tuned (AEM EMS). The supercharger was removed, engine turned back to stock, and the car was sold to a friend of mine. It has been running fine and all of a sudden there is a knocking noise.
Posibilities:
Rod knock (bearing clearance to big)
Rockers (valve clearance to big)
Others?
Old Aug 5, 2005 | 05:23 AM
ranta18's Avatar
Default Re: Engine Knocking ??? (ranta18)
From what I've been told (I haven't heard it yet, but will tonight) its coming from the block area. They took the pan off and looked at the rods (didn't take the caps off or look at the bearings) and there was little movement and everything looked ok. Rockers looked ok. What else?
Oh... it was also a quart low on oil when the knocking was first heard.
Old Aug 5, 2005 | 09:39 AM
Mr. Bagel's Avatar
unsure but curious to know what you find out.
Old Aug 5, 2005 | 12:47 PM
Scot's Avatar
my racing S2000 had a similar problem and it was oil starved.... my #1 piston wall was scored all to hell.
i ended up buying a new OEM shortblock and a baffled oil pan to help prevent the problem.
Everyone thought my problem was a rod bearing until they dug into it.
goodluck.
Old Aug 5, 2005 | 01:02 PM
Mr. Bagel's Avatar
Default Re: (Scot)
Scot, what other symptoms did you have when this happened? Also wondering what kind of troubleshooting they did prior ot discovering the scored walls.
Old Aug 6, 2005 | 11:48 AM
ranta18's Avatar
Default Re: (Mr. Bagel)
Motor is FUCKED! I'll post some pictures of the piston. The top/side of it is all messed up, combustion chamber messed up, etc. I guess thats what happens when you boost and don't tune.
Old Aug 7, 2005 | 05:21 PM
ranta18's Avatar
Default Re: (ranta18)
OUCH!!!
Old Aug 7, 2005 | 05:29 PM
Mr. Bagel's Avatar
crap. sorry to hear.
Old Aug 7, 2005 | 05:56 PM
Scot's Avatar
mine went from "running great" and winning a race to really noisy within a matter of minutes..... i was running no exhaust from the test pipe back, so who knows how long it was actually making noise....i only heard it once I put an exhaust on the car.
Mine didn't look like that one, but my #1 cylinder was completely scored...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Bagel &raquo;</TD></TR><TR><TD CLASS="quote">Scot, what other symptoms did you have when this happened? Also wondering what kind of troubleshooting they did prior ot discovering the scored walls.</TD></TR></TABLE>
Old Aug 7, 2005 | 06:45 PM
fknfast's Avatar
Default Re: (Scot)
what are you goin to do about a motor now??
Jaycrv
Honda CR-V & Element
Jul 8, 2017 02:22 PM
farhan445
Nov 21, 2006 07:03 PM
stewdabaker
Feb 24, 2006 03:15 PM
ranta18
Aug 7, 2005 05:20 PM
Mover
Apr 3, 2002 08:56 PM
