Honda S2000 Honda S2000
Differences in S2000 from 2000- 2003?
Old Nov 16, 2003 | 07:47 AM
SpoonSpecR's Avatar
Default Differences in S2000 from 2000- 2003?
In the market for a slightly used S2k and would like to know what changes were made to car in the first years. I am aware of whats new on the '04, just interested in '00-'03.
Exterior, Interior, SoftTop changes, suspension adjustments???
Thank you in advance
Old Nov 16, 2003 | 08:02 AM
munckee's Avatar
Default Re: Differences in S2000 from 2000- 2003? (SpoonSpecR)
00-01: windscreen added; floor mats became standard equipment
01-02: glass window, door tweeters, suspension, tranny, and ecu tweaks
02-03: color changes only
Old Nov 16, 2003 | 08:17 AM
SpoonSpecR's Avatar
Default Re: Differences in S2000 from 2000- 2003? (munckee)
So in everyones opinion; Is an '02 the best used one to buy? Most of the '02's are a bit more than I would like to spend.
Is the soft top motorized? Glass rear window? How does this work?
Old Nov 16, 2003 | 09:13 AM
CD5sam's Avatar
the soft top is motorized. the MY02+ has a glass rear window which is more durable thanthe old plastic window. try to get a 02+, most problems were fixed. search on http://www.s2ki.com and you'll get good results too.
Old Nov 16, 2003 | 09:16 AM
munckee's Avatar
I'd disagree. If an '02 will be a stretch for you then go with the older one and buy in your comfort range. The changes between the '02 and the earlier models were minimal. Yes, it has a more durable glass window, but it's also half the size of the plastic one. If you take care of the plastic, you'll be fine. I've never heard anyone praise the door tweeters; you'll either replace the stereo or you won't. The suspension and ECU tweaks were minor...very minor.
If an '00 is in the range you want to spend, go for it. Keep in mind that this car will eat tires faster than most others and the insurance might be higher, so the extra money will have some meaning down the road.
Old Nov 16, 2003 | 12:02 PM
03_AP1's Avatar
Default Re: (munckee)
people are going to defend their MY's.
Personally, i've driven both a platic and glass window'd s2000. Lemme say this, size doesn't matter, as you're limiting factor is the size of the rearview mirror anyways.
There are more changes between 02-03 than listed here. Go to the libary at http://www.s2ki.com for extensive discussion about the differences.
Old Nov 16, 2003 | 04:52 PM
H22A EG6's Avatar
Default Re: (03_AP1)
iheard that the 02<S2000<04 had more power
Old Nov 16, 2003 | 09:37 PM
Atoku's Avatar
Default Re: (H22A EG6)
I own a MY '00 and love it but I would not suggest that anyone buy a used '00 or perhaps even the '01. I've seen too many problems with the differential, transmission, clutch and even the infamous #4 cylinder problem. The soft tops have a problem with spots wearing thin behind the side windows as well. I haven't heard the same problems with any significant frequency once the '02 came out. Most of these things could be fixed under warantee but often the dealer (or AHM) would refuse so the problems could remain in a few of these cars.
Whether or not these issues were actually fixed with changes to the design over the years will only be known after we rack up some more miles on the later cars. I have over 60K now but my tranny, diff and clutch were all replaced before 36K.
Old Nov 17, 2003 | 08:44 AM
SpoonSpecR's Avatar
Default Re: (Atoku)
^ Good info!
Old Nov 17, 2003 | 08:45 AM
SpoonSpecR's Avatar
Default Re: (SpoonSpecR)
Are the soft tops power?
Old Nov 17, 2003 | 10:39 AM
turbologist's Avatar
Are there any other sites where i can find one....Ive been lookin for quite a while now and I been to:
http://www.cars.com
http://www.autotrader.com
http://www.s2ki.com
Havent found one that I liked yet...
Old Nov 17, 2003 | 01:16 PM
SpoonSpecR's Avatar
Default Re: (Turbologist)
^ In the same boat myself!!!! I can't find a white or Yellow '01 or '02 On the west coast under 25k
Old Nov 17, 2003 | 06:54 PM
Cornbread Jr.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonSpecR &raquo;</TD></TR><TR><TD CLASS="quote">^ In the same boat myself!!!! I can't find a white or Yellow '01 or '02 On the west coast under 25k </TD></TR></TABLE>
I live in Dallas and I can find 2000-2003 models for less than 25k all day long. I'll be in the market for one too in about 2 months.
Old Nov 17, 2003 | 06:59 PM
M-Type's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by munckee &raquo;</TD></TR><TR><TD CLASS="quote">I'd disagree. If an '02 will be a stretch for you then go with the older one and buy in your comfort range. The changes between the '02 and the earlier models were minimal. Yes, it has a more durable glass window, but it's also half the size of the plastic one. If you take care of the plastic, you'll be fine. I've never heard anyone praise the door tweeters; you'll either replace the stereo or you won't. The suspension and ECU tweaks were minor...very minor.
If an '00 is in the range you want to spend, go for it. Keep in mind that this car will eat tires faster than most others and the insurance might be higher, so the extra money will have some meaning down the road.</TD></TR></TABLE>
for the amount of money you save from buying a used 00 vs 02, you can buy aftermarket stuff to match or beat a stock 02
Old Nov 18, 2003 | 07:02 AM
...<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonSpecR &raquo;</TD></TR><TR><TD CLASS="quote">^ In the same boat myself!!!! I can't find a white or Yellow '01 or '02 On the west coast under 25k </TD></TR></TABLE>
lol....I been lookin for a white one too but im on the other coast...I guess we need to be patient...
Old Nov 18, 2003 | 09:53 AM
SpoonSpecR's Avatar
There are quite a few on the east coast -Florida, and a ton in Texas.
Old Nov 18, 2003 | 03:02 PM
M-Type's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonSpecR &raquo;</TD></TR><TR><TD CLASS="quote">There are quite a few on the east coast -Florida, and a ton in Texas.</TD></TR></TABLE>
yup all the good deals on s2ki are around tx
Old Nov 23, 2003 | 10:53 AM
scs2k's Avatar
wait a min, i thought that the 00 - 01 were more quicker than the 02-04 s2000 since nowadays most vechicles are becomming user friendly. such as quarter mile times 00-01 are running at 13.9 and 02 and up are running about 14.9 thats pretty crazy
http://car-stats.com/stats/search/chooseyear.aspx
Old Nov 23, 2003 | 12:06 PM
BerlinaAP2's Avatar
Default Re: (scs2k)
i searched in here lat night and saw dyno charts that show the 02 and 03 models consistently put out more power than the 00 and 01. hope that helps.
Old Nov 23, 2003 | 12:32 PM
icbmatt's Avatar
Go for an 02+, glass windows is worth it... Those plastic windows could be expensive in the long run.
Old Nov 23, 2003 | 08:37 PM
munckee's Avatar
Default Re: (cmgi8@yahoo.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmgi8@yahoo.com &raquo;</TD></TR><TR><TD CLASS="quote">Go for an 02+, glass windows is worth it... Those plastic windows could be expensive in the long run.</TD></TR></TABLE>
Again, I whole-heartedly disagree. If he's that worried about the plastic window, he could take the money he saves over an 02 and buy a hardtop. The plastic window is easy to care for. If you do care for it correctly, it lasts just fine.
Old Nov 24, 2003 | 08:40 AM
SpoonSpecR's Avatar
he could take the money he saves over an 02 and buy a hardtop. </TD></TR></TABLE>
^ Thats the plan
97ex082391
Honda S2000
Apr 28, 2011 08:17 PM
briangotti
Honda S2000
33
Feb 2, 2010 10:23 PM
Hiroshima_VTi-S
Honda S2000
Feb 12, 2008 08:10 PM
eLeCtRoNSi00
Honda S2000
15
Feb 6, 2006 05:40 AM
boostedhb
Honda S2000
Mar 28, 2005 10:07 PM
