Honda S2000 Honda S2000
Comptech Intake?(Alignment issue)
Old Jul 26, 2005 | 03:44 PM
NAem1's Avatar
Default Comptech Intake?(Alignment issue)
Like the title says. Im having trouble lining up the Comptech box on my 00' S2000. The intake fits fine as well as the 3 bolts to secure the box. My problem as you can see in the photo is that the rod that holds the hood up is about a 1/4 of an inch off. I have to FORCE the rod into the slot. Has anyone else had this issue? Did you end up drilling new holes to move the box forward? Any help is appreciated!
This is the slot I am referring to...
Box with hood rod down. I did shave the end of the rod as comptech stated.
Thanks for any help.
Old Jul 26, 2005 | 04:03 PM
CWESTINAP1's Avatar
Default Re: Comptech Intake?(Alignment issue) (NAem1)
just get some hood dampers.
Old Jul 26, 2005 | 04:23 PM
revhi's Avatar
None of the hood props fit through the Comptech intake hole. Everyone has the same problem. I bent the hood prop and shaved it down a bit to fit better, but still not perfect. As Cwest said, I got Tein hood dampers now.
Old Jul 26, 2005 | 04:58 PM
NAem1's Avatar
Default Re: (revhi)
yeah I think I may go to the hood dampers also. Thanks a lot for the help!
Old Jul 26, 2005 | 05:00 PM
.doeboyfresh.'s Avatar
From: Boswanna,street radio,riddin in da regal. PA.LLday
Default Re: (NAem1)
this is all a common prob. like the hood damp. idea....also anyone know a price on them?
Old Jul 26, 2005 | 05:15 PM
NAem1's Avatar
Default Re: (TeGmAn18)
looking around $130-$140 for them.
Old Jul 26, 2005 | 05:19 PM
Default Re: (NAem1)
hmm this may be a bad idea if u have a cf hood i would think it would bow up
Old Jul 26, 2005 | 06:07 PM
revhi's Avatar
I know people with c/f hoods and the dampers, no problems.
Old Jul 26, 2005 | 07:13 PM
tmkpres's Avatar
Default Re: (revhi)
I just shaved the hole a lil bigger so that it would fit without shavvin the rod
Old Jul 26, 2005 | 09:09 PM
xenosis's Avatar
can either get a dremel and widen it, or get hood dampers. lastly you can just not use your hood prop,but eh*shrugs*
Old Jul 26, 2005 | 09:21 PM
Mr. Bagel's Avatar
Default Re: (tmkpres)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tmkpres &raquo;</TD></TR><TR><TD CLASS="quote">I just shaved the hole a lil bigger so that it would fit without shavvin the rod</TD></TR></TABLE>
Good idea. I have this problem, but I just deal with it and have for several years. I think I got in on the second batch of these CAIs early on.
Old Jul 26, 2005 | 10:52 PM
tmkpres's Avatar
Default Re: (Mr. Bagel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Bagel &raquo;</TD></TR><TR><TD CLASS="quote">
Good idea. I have this problem, but I just deal with it and have for several years. I think I got in on the second batch of these CAIs early on.</TD></TR></TABLE>
Yeah I found it to be the easiest way, I didn't want to shave the prop, so the lid was a no brainer.
Old Jul 26, 2005 | 11:59 PM
DragonHeart's Avatar
The hood prop will not fit....Some guys have dremeled the CF lid....I got the Tein Hood Dampers..
Once you have the hood dampers you will never look back....
EM1Guru
11
Nov 18, 2003 08:15 PM
LillDragun
Oct 16, 2002 10:44 PM
dohcgarage
Jan 3, 2002 07:25 AM
ITR1078
Sep 22, 2001 05:45 PM
