Honda S2000 Honda S2000
Comp?
Old Feb 23, 2006 | 11:30 AM
EJ8 GSR-T's Avatar
Default Comp?
HEy i have an s2000 comptec supercharged, but i am doing a rebuild, due to some fuel prob.'s but my question is if i plan to up the boost from 6 to like 10 or 12, what is a good compression ratio?
Old Feb 23, 2006 | 01:57 PM
EJ8 GSR-T's Avatar
Default Re: Comp? (userdead626)
also where can i find forged pistons for my s2k!
Old Feb 23, 2006 | 02:11 PM
Nighthawk R18's Avatar
is it an ap1 or ap2?
Old Feb 23, 2006 | 02:18 PM
EJ8 GSR-T's Avatar
Default Re: Comp? (VTEC Genetics)
ap1 i believe 2003 its the f20c.....9000k redline 2.0 liter
Old Feb 23, 2006 | 04:16 PM
revhi's Avatar
Stock can handle up to 11psi with upgraded injectors and ecu
Old Feb 23, 2006 | 05:25 PM
for pistons use ARIAS..about 89mm with 10.5:1 c/r with a comptech s/c...about 12 lbs of boost...about $580 without the rings
Old Feb 23, 2006 | 06:20 PM
EJ8 GSR-T's Avatar
so 8.8:1 may be a bit low?
Old Feb 23, 2006 | 07:49 PM
well i was answering the forged pistons question..
but yes 8.8:1 is too low..stock is 11:1. remember s/c get hot after 13psi...my suggestion is instead of rebuilding the block, get a feul management system..with 8.8 c/r and 12 psi you car will do no better than 12.5 1/4 mile runs
Old Feb 24, 2006 | 10:10 AM
EJ8 GSR-T's Avatar
hmm how much hp do you think 12psi with 8.8:1 will get me?
Old Feb 24, 2006 | 04:25 PM
around 330-350
92CHB
Oct 10, 2011 07:36 AM
projectef
Aug 24, 2007 07:08 AM
accorracer
May 3, 2003 11:45 AM
Fatty_1775
Feb 26, 2003 06:21 PM
