Honda S2000 Honda S2000
code 1106
Old Dec 23, 2007 | 01:55 PM
EJ8 GSR-T's Avatar
Default code 1106
Can anyone give me a little better explanation of what this is?
Old Dec 23, 2007 | 02:06 PM
LAS2K's Avatar
Default Re: code 1106 (EJ8 GSR-T)
http://www.s2ki.com
go to their Under the Hood section. There will be a list of codes there.
Sorry can't direct link, s2ki is blocked at work.
Old Dec 23, 2007 | 02:38 PM
EJ8 GSR-T's Avatar
Default Re: code 1106 (LAS2K)
P1106 BARO Circuit Range/Performance
Kinda the same thing my scanner said, but i dont quite understand what that means and or how to fix it.
Old Dec 23, 2007 | 05:45 PM
Flexmyrex's Avatar
The barometric sensor is integrated in the PCM on hondas. Its the sensor to determine altitude/changes in atmospheric pressure. I would try erasing the DTC and reseting the PCM as it could only be an intermittent problem. If the problem comes back you will need to replace the PCM, you can't replace the sensor itself and most likely have a damaged printed circuit board/sensor.
Old Dec 23, 2007 | 07:56 PM
EJ8 GSR-T's Avatar
Default Re: code 1106 (Flexmyrex)
Well the car is FI, so it sounds like that may have something to do with it..?
Old Dec 23, 2007 | 08:54 PM
Flexmyrex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">Well the car is FI, so it sounds like that may have something to do with it..?</TD></TR></TABLE>
Do you have any other DTC besides the P1106?
Being FI has nothing to do with the baro sensor, its primary purpose is to measure atmospheric pressure- it has now way of knowing what your manifold pressure is. The MAP sensor is what determines weather your engine is pulling vacuum or building pressure.
Old Dec 24, 2007 | 09:30 AM
EJ8 GSR-T's Avatar
Nope no other codes...where is the baro sensor?
My understanding is that since there is a difference map sensor on the car (it has the stock sensor and a denso 3bar) that the voltage from the map sensor does not agree with the baro sensor...am i totally wrong?
Old Dec 24, 2007 | 09:52 AM
Flexmyrex's Avatar
If you have a 3 bar sensor on there now then yes you may just need to rescale the MAP sensor. The MAP and Baro should read the same voltage with key on engine off, the PCM will monitor these inputs and will consider it a malfunction if the two voltages are offset.
Old Dec 24, 2007 | 10:44 AM
EJ8 GSR-T's Avatar
How do i get them to be within spec? The shop recommended putting a missing link on the stock sensor which i did, but to no avail... :-/
Old Dec 25, 2007 | 08:57 PM
EJ8 GSR-T's Avatar
bump still need ideas
Old Dec 28, 2007 | 08:29 AM
EJ8 GSR-T's Avatar
Old Jan 1, 2008 | 02:47 PM
EJ8 GSR-T's Avatar
hondaaccordf23
Oct 25, 2012 03:54 PM
cmsrally
12
Jan 25, 2006 08:34 AM
LoseRPunKx182
Aug 16, 2005 03:34 PM
HCRX311
Jun 7, 2005 11:55 AM
stehigs321
Jan 5, 2004 12:28 AM
