Honda S2000 Honda S2000
Clutch Question
Old Jan 29, 2006 | 07:23 AM
marshallhunting's Avatar
Default Clutch Question
First off I would like to introduce myself, I have recently joined the ranks and I am a proud owned of an AP1. The car has given me great pleasure and it’s been exciting learning how to drive it. I am a former owner of 2 SR20 powered S-13s and a 300ish AWHP DSM. I have decided to go w/ the S2000 because of its reliability and better street manners not to mention A/C . I live near the mountains of western North Carolina. And can quite often be found on some of the more famous roads in the area. This coming season I plan to do as many track events as possible and maybe a few auto crosses, so I look forward to meeting some of you.
That said, I have a question concerning the clutch system. The car is equipped with and exedy stage 3 clutch and the engagement point only occupies about 10% of the pedal throw, the pedal also releases very quickly and it makes driving in high traffic areas a PITA. Have any of you had any success w/ removing the clutch damper box (if there is one) also In past searches I have seen the AP2 slave cylinder engages slower, is this true and is it possible to change it? Any help would be appreciated.
Marshall
Old Jan 29, 2006 | 07:48 AM
MattHonda's Avatar
Default Re: Clutch Question (marshallhunting)
Welcome
Old Jan 29, 2006 | 08:56 AM
LAS2K's Avatar
Default Re: Clutch Question (Matt_)
the engagement point is about the same on mine. i have no idea on how to remove the damper box. my suggestion is just to get used to it. i live in LA where traffic is 1000x worse than what you have.
yes it is a bit annoying but it would be about the same anyways in traffic if you did remove the box.
Old Jan 29, 2006 | 10:10 AM
HXMan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marshallhunting &raquo;</TD></TR><TR><TD CLASS="quote">
All you have to do is swap in an AP1 slave cylinder. The clutch damper is an integral part of the AP2 slave cylinder.
Old Jan 29, 2006 | 11:02 AM
djSALIX's Avatar
Default Re: Clutch Question (HXMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXMan &raquo;</TD></TR><TR><TD CLASS="quote">All you have to do is swap in an AP1 slave cylinder. The clutch damper is an integral part of the AP2 slave cylinder.</TD></TR></TABLE>
He has an AP1
guy_from_nerk
Nov 4, 2009 12:17 PM
Nay
May 16, 2005 09:05 AM
Echo2218
Honda S2000
Apr 9, 2005 07:04 PM
