Honda S2000 Honda S2000
Check Engine Light help!!! plz
Old Dec 26, 2007 | 04:52 AM
MADBADGER's Avatar
Default Check Engine Light help!!! plz
i was just driving and my cel just popped on. i'm running a test pipe (invidia 70mm) it has the 02 fix in it and i've ran it for a couple of weeks without the cel, but what makes me think its not that is, after my car has been sitting all night the cel comes on when i turn the key before the car is even started??? help please
Old Dec 26, 2007 | 06:05 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Check Engine Light help!!! plz (MADBADGER)
did u pull the code to see if it was the O2?
Old Dec 26, 2007 | 06:33 AM
Black S2K's Avatar
Yea dude get the code pulled
Old Dec 26, 2007 | 08:00 AM
MADBADGER's Avatar
Default Re: (Black S2K)
yead its the ok, wtf why would it just pop on
Old Dec 26, 2007 | 10:25 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (MADBADGER)
so u pulled the code and its the O2?
have you checked the wires? sometimes when installing them the wires hang and could have frayed a bit causing bad signals to the ECU
Old Dec 27, 2007 | 10:14 PM
B-Seriuz's Avatar
Default Re: (S@nt0s)
mine came on after changing my clutch. turns out i started my car with the 02 not plugged in all the way. pulled the 7.5 fuse under the dash for 5 mins plugged it back in restarted the car and it went away. of course i had to let the ecu learn itself again..or you can just take it to advanceauto and let them check out the code for you there should be no fee. dont take it to autozone they'll just end up trying to sell you sumthing you dont need.
Modified by B-Seriuz at 11:30 PM 12/27/2007
ITRBOY1433
Honda S2000
12
Oct 20, 2010 07:50 AM
Kris's turbo
Apr 10, 2009 07:24 AM
NaCk3m
Apr 9, 2007 10:11 AM
wilsel
Apr 15, 2005 05:18 AM
HondaCutter
Jan 2, 2003 03:46 PM
