Honda S2000 Honda S2000
Check engine light
Old Jul 13, 2004 | 12:31 PM
Draven_Von's Avatar
Default Check engine light
i have a 2000 S2000 and i'm getting a check engine light coming on.
the ride is sometimes ruff. the dealer checked it out and said it's a bent valve because the car has been run too hard. they are accussing me of racing the car. now come on guys, this car just runs hard in the first place. and i don't race the thing. my gf drives it most of the time. before that, they said it was mis-firing. and they made valve adjustments. but the check engine light is back. another mechanic said that we're not using quality gas and it's clogging the fuel injectors. now another one is saying the spark plug wires are causing the mis firing. has anyone else experience anything like this? please help.
Old Jul 13, 2004 | 12:38 PM
Mr. Bagel's Avatar
Default Re: Check engine light (Draven_Von)
IF it is a bent valve, the car would run very rough. You would be able to hear the studdering at the tail pipe. Yes, it's that obvious. Anything else could result from cheap gas to something else minor or major. A misshift is the only thing that will cause a valve to bend. Not by just driving the car hard, but by misshifting - hitting 2nd instead of 4th when you are hitting 9k rpms.
Old Jul 13, 2004 | 08:22 PM
papa5murf's Avatar
i say take it to a different dealer, preferably a dealer that has a s2k tech...
Old Jul 14, 2004 | 03:45 PM
SuzukaBlueAP2's Avatar
Here's a novelty idea...how bout checking that CEL and see what the code is that it's throwing? Or would that not make sense?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Bagel &raquo;</TD></TR><TR><TD CLASS="quote">IF it is a bent valve, the car would run very rough. You would be able to hear the studdering at the tail pipe. Yes, it's that obvious. Anything else could result from cheap gas to something else minor or major. A misshift is the only thing that will cause a valve to bend. Not by just driving the car hard, but by misshifting - hitting 2nd instead of 4th when you are hitting 9k rpms.</TD></TR></TABLE>
I'm not disagreeing, but not always does a mis-shift result in damaged hardware. But you are correct, that is something that should be audible in the exhaust, and possibly even with the hood popped and engine running. Depending on how bad it is.
One other thing that you could do is perform a compression/leakdown test.
Old Jul 17, 2004 | 11:53 AM
Steve-'s Avatar
same thing happened to my brother have you changed the spark plugs if not honda has a Recall on the spark plugs also
Old Jul 19, 2004 | 12:48 PM
Draven_Von's Avatar
Default Re: Check engine light (dc2 integi2a 00)
AFTER HONDA CHANGED THE SPARK PLUGS... YOU DIDN'T HAVE ANY PROBLEMS?
WE HAVE ALREADY HAD THEM CHANGE IT AND WE'RE STILL GETTING THE LIGHT
Old Sep 13, 2005 | 08:07 AM
Blue Hybrid's Avatar
Default Re: Check engine light (ScreaminTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">Here's a novelty idea...how bout checking that CEL and see what the code is that it's throwing? Or would that not make sense?
One other thing that you could do is perform a compression/leakdown test.</TD></TR></TABLE>
hes right, just do a compression test (see if its holding pressure) and if its not, do a leakdown (see where its leaking from) YOU LET YOUR GF DRIVE YOUR S2K o.O
Old Sep 13, 2005 | 08:18 AM
Nishant's Avatar
Default Re: Check engine light (gold EF)
what code is the CEL showing?
Old Sep 13, 2005 | 08:27 AM
Mr. Projekt's Avatar
* B A N N E D *
Just some random stuff that set off the CEL the Berlina I had:
-Primary O2 sensor failed.
-Secondary O2 sensor deteriorated, the tip was loose inside the cat. (changed to test pipe)
-The airhose between the air pump and intake was kinked, throwing a CEL. (fixed in 2 minutes)
Only way I found out is by having a Honda mechanic read my codes.
Honhel
Honda Fit
Sep 21, 2015 10:53 AM
angryk
Honda Civic (2001 - 2005)
Dec 28, 2007 11:53 AM
sergei_sh
Mar 13, 2006 06:19 PM
