Honda S2000 Honda S2000
Cel p1399
Old Feb 10, 2009 | 05:06 PM
TypeR324's Avatar
Default Cel p1399
So yesterday under heavy acceleration my CEL blinked on a few times maybe 3-4 times (It immediately turned off and stayed off). I took the car to autozone and had them pull the code and P1399 came up. I tried to look up the code online but I didn't see that code listed. I did a search and through another post I found that it means, "Manufacturer Control Ignition System Error." Anyone have any ideas on this, maybe a link with possible troubleshooting options? Thanks in advance.
Old Feb 10, 2009 | 05:21 PM
ekb16's Avatar
Default Re: Cel p1399
after searchin around i came up with a misfire code..try checking ur spark plugs
Old Feb 10, 2009 | 05:27 PM
h_s's Avatar
h_s
right off all data
p1399 is a random misfire code and honda has reported for various models that this could be caused by clogged egr ports, in addition there is the possibility that the valve clearance spec may be out of range
Old Feb 11, 2009 | 09:57 AM
TypeR324's Avatar
Thanks for the info guys. One last question, when the check engine light blinks on a few times then turns off is it telling me there is a serious problem with the car or should I not be that concerned?
Old Feb 11, 2009 | 10:37 AM
ekb16's Avatar
most misfire codes will cause the MIL to blink instead of stay on..everytime it misses the MIL will blink and goes off
Old Feb 11, 2009 | 11:35 AM
White Smoke's Avatar
i my honda
Global Mod
Usually the bad blinking light stays blinking. But when it blinks, it's always bad. Check your plugs and go from there. Would not hurt to do a compression test while you at it.
Old Feb 11, 2009 | 11:51 AM
Honda Sport's Avatar
hopefully you've pumping 91/92 octane also...
Old Feb 11, 2009 | 12:06 PM
MidwestAutoWorks's Avatar
Originally Posted by h_s
right off all data
No EGR ports in these cars..
I just had this code also, changed my spark plugs which were the originals and at like a .70 gap and bam all better, car runs way better too now
Old Feb 11, 2009 | 01:00 PM
i my honda
Global Mod
Great point...
Old Feb 11, 2009 | 03:05 PM
TypeR324's Avatar
I typically use 93 but I did use 91 when the CEL came on but that shouldnt be a problem.
Old Feb 12, 2009 | 09:15 AM
papa5murf's Avatar
If you're having random misfires it's not good. If it's not your spark plugs that's the issue then your coil packs are going or are already bad.
The Ap1's occasionally had issues with coil packs failing. My coil packs caused random misfires and ended up putting a little hole in my headgasket. But then again, I was also pushing 18psi at the time.
Old Aug 7, 2011 | 06:24 AM
4G92's Avatar
Would this code also cause the knock sensor to foul up? P0325 is also being tossed out.
Old Aug 7, 2011 | 12:47 PM
postman's Avatar
the knock sensor is setting because of the misfires. check your spark plugs. if they look ok, inspect your valve clearances and valve retainers/keepers while your at it. look at your coilpacks for signs of burning or overheating.
jwagner
Engine Management and Tuning
Apr 8, 2012 07:38 PM
PowerHouse
Nov 12, 2004 04:01 AM
emanLS
Oct 20, 2003 01:15 PM
AamirCWITR
Jun 25, 2003 01:47 PM
CapnChunk
Mar 23, 2003 07:33 AM
