Honda S2000 Honda S2000
CEL incorrect arflow
Old May 26, 2008 | 05:16 PM
dartonh22's Avatar
Default CEL incorrect arflow
2000 honda s2000 123,000 miles, just bought it, the check engine light is on and i got it scanned it read incorrect aiflow, the top of the intake box is off and there is a cone stlye filter on the intake pipe, what can cause this code,
i did not do the intake mod it was like that when i bought it.
Old May 26, 2008 | 08:26 PM
Mase's Avatar
Default Re: CEL incorrect arflow (dartonh22)
probably faulty map sensor?
Old May 27, 2008 | 04:13 AM
HondaKyle's Avatar
You know when the top of the intake box is off your car is sucking in hot air...
Old May 27, 2008 | 04:31 AM
dartonh22's Avatar
Default Re: CEL incorrect arflow (HondaKyle)
yeah i know like i said i didn't do it and i dont have the cover for it, i guess the previous owner wanted the sound. i cleared the code and it hasn't came back yet, but i didnt fix anything so i am expecting it to come back on. just wanted to know what faulty electronics could throw this code.
Old May 27, 2008 | 04:43 AM
HondaKyle's Avatar
Just making sure cuz a lot of people take them off. I doubt the code will come back...
Old May 27, 2008 | 01:44 PM
jdm j's Avatar
Check all your vacuum hoses!
Old May 27, 2008 | 04:48 PM
Black S2K's Avatar
Default Re: (jdm j)
^x2 it could be your secondary air injection system. I threw a code for that too and it I couldent figure it out for the longest time. The metal vacum lines that run to the seconday air injection system valve and solonoid rubbed against my strut bar and created a hole in both of the lines. this was causing the incorrect flow. So check all your vacume lines.
Old May 27, 2008 | 06:42 PM
em_ekohc's Avatar
There is actually a service bulletin on all 00-05 s2k's (SB 06-055) it says the air pump relay can stick and cause the air pump to overheat and throw a number of codes one of which being being p0411 (secondary air injection system incorrect flow)
Old May 29, 2008 | 07:10 AM
dartonh22's Avatar
Default Re: (em_ekohc)
okay my cel came back on and i checked all the hoses going to the box and the solenoid and they are all new and in good shape, but i dont know if theyre on the right way, does anyone know how i can check to make sure the air pump relay is working
Old May 29, 2008 | 08:58 PM
m1northreat's Avatar
check to make sure that the plug right behind the intake box is plugged in. i just recently had my clutch done and i got the same CEL and prolly the same code.
Old May 31, 2008 | 08:55 AM
Derek14's Avatar
Default Re: (m1northreat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m1northreat &raquo;</TD></TR><TR><TD CLASS="quote">check to make sure that the plug right behind the intake box is plugged in. i just recently had my clutch done and i got the same CEL and prolly the same code. </TD></TR></TABLE>
I agree. This code is either your vacuum lines not seated properly, or your vacuum control soleniod valve disfunctioning.
I had to replace mine after 95K (just a month ago). Small valve bolted to the rear of the intake box. I got mine used from a member on s2ki for $25.00 shipped... Give that a look
Old Jun 6, 2008 | 10:42 AM
dartonh22's Avatar
Default Re: (Derek14)
finally got around to taking off my bumper to check the air pump, it was all good, so i started replaceing all my vacuum lines and i found a cut in the one by the firewall connected to a vacuum soenoid and that fixed it thanks for all your help.
Old Jun 6, 2008 | 12:52 PM
Black S2K's Avatar
lol told you it was one of the lines. oh well i did the exact same thig i tore that **** apart b4 i found the two holes that rubbed through.
Old Jun 7, 2008 | 03:11 AM
dartonh22's Avatar
Default Re: (Black S2K)
danit the stupid light is back on, i guess i need to change some more vacuum lines
the code was p0411
Old Jun 8, 2008 | 03:35 PM
dartonh22's Avatar
Default Re: (dartonh22)
well i replaced all vacuum lines and the light still comes back on after resetting the ecu, does anyone have pics of the vacuum diagrams or theyrs engine bay up close where the hoses are and know which way the check valve is supposed to go.
godruler
Oct 12, 2009 06:48 PM
nhinnhuckyduc
Honda S2000
Nov 8, 2006 02:32 PM
JDMAllMota R731
Aug 12, 2002 09:12 AM
