Honda S2000 Honda S2000
cams on a s2k
Old Aug 31, 2003 | 12:04 AM
NightHawkC5's Avatar
Default cams on a s2k
what companies make cams and which is the best? please give the rpms where it improves the most
Old Aug 31, 2003 | 09:09 AM
Razor's Avatar
Default Re: cams on a s2k (NightHawkC5)
toda cams version 2
Old Aug 31, 2003 | 11:53 AM
oos2kfan
Guest
Posts: n/a
Toda makes a good set of cams, but they also push the valvetrain to the farthest limits so be careful.
Old Aug 31, 2003 | 12:10 PM
Razor's Avatar
Default Re: cams on a s2k (oos2kfan)
thats why you also need to upgrade the valve train, definately need some beefier valve springs
Old Aug 31, 2003 | 03:33 PM
oos2kfan
Guest
Posts: n/a
Default Re: cams on a s2k (Razor)
Yeah definitely. You may also check out inlinefour.com they have a set of Spoon Sports cams for the S2000.
http://www.inlinefour.com/spoons2racca.html
Old Aug 31, 2003 | 05:07 PM
are toda ver 2's out and is it safe to put a thinner spoon head gasket if u have toda cmas with the valvetrain
Old Aug 31, 2003 | 06:16 PM
oos2kfan
Guest
Posts: n/a
I can't say for sure, but the Toda pushes the valves out to the very limits so lowering the gasket size seems like a risky move. You may end up with the valves slapping the pistons
Old Aug 31, 2003 | 07:20 PM
Razor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightHawkC5 &raquo;</TD></TR><TR><TD CLASS="quote">are toda ver 2's out and is it safe to put a thinner spoon head gasket if u have toda cmas with the valvetrain</TD></TR></TABLE>
oos2kfan is correct. i think i even remember a note by toda saying how you shouldn't use a thinner head gasket for the obvious reasons. and yes the toda version 2's are out. a guy on http://www.s2ki.com has them, his name is beroz i think.
Old Aug 31, 2003 | 07:50 PM
oos2kfan
Guest
Posts: n/a
Here is a link to the Toda site: http://www.todaracing.com/prod....html
Make sure to read the note at the bottom.
Razor, you are a tech right? How much is installation on a set of cams, valves and valve springs? And does anyone have a dyno chart for these cams?
BTW just parts you are looking at $1700 or so...
Old Aug 31, 2003 | 08:20 PM
Razor's Avatar
no im not a tech, i just work at the honda dealership. i also am not sure about the labor costs since i never asked. sorry.
Old Aug 31, 2003 | 11:04 PM
oos2kfan
Guest
Posts: n/a
ahh gotcha sorry about that
an2ny888
May 3, 2005 08:27 PM
teethandnails
Oct 23, 2004 04:49 PM
civictyper85
Jan 6, 2002 06:18 PM
