Honda S2000 Honda S2000
Break Caliper Help
Old Oct 27, 2004 | 07:43 PM
elwood's Avatar
Default Break Caliper Help
I have read that the mugen activegate setup
uses s2000 calipers. Meaning that stock
s2000 calipers will fit on a ITR setup. Are the
mugen calipers modified from the stock setup,
or will the stock calipers work for me?
Also, the stock s2000 are a 2 piston caliper correct?
Thanks
elwood
Old Oct 27, 2004 | 08:05 PM
WowOzYouRock's Avatar
Default Re: Break Caliper Help (elwood)
Old Oct 27, 2004 | 08:53 PM
elwood's Avatar
Default Re: Break Caliper Help (Y2K_S2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K &raquo;</TD></TR><TR><TD CLASS="quote">? </TD></TR></TABLE>
thanks for the help.......
Old Oct 27, 2004 | 09:47 PM
thk's Avatar
thk
Members Only
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elwood &raquo;</TD></TR><TR><TD CLASS="quote">I have read that the mugen activegate setup
Thanks
elwood</TD></TR></TABLE>
IIRC, single piston. I haven't swapped pads/rotors yet but I'm fairly sure it's single.
And no, if I'm guessing your question correctly (trying to use OEM calipers on a DC2R/EK9R/yadda yadda). S2K calipers will not fit on your car. Again, IIRC but Mugen sourced out the carriers to make the S2K calipers fit and match the DC2. I could be wrong though.
Old Oct 27, 2004 | 10:09 PM
evil vapor's Avatar
Default Re: Break Caliper Help (thk)
*I think* that the rotor spacing is different from the DC5/DC2, and brackets would be needed for the caliper in order for the setup to work. If you're on a budget, try running a wilwood brake kit.
Old Oct 28, 2004 | 10:22 AM
Ahhvtec1's Avatar
Default Re: Break Caliper Help (vapor)
I am with Vapor, go with the Wilwood. The S2k brake caliper is a single sliding piston BTW.
Old Oct 31, 2004 | 07:16 PM
S2KGirlie's Avatar
mugen modded the s2k caliper its not bolt up. Just get a nsx caliper elwood
Old Oct 31, 2004 | 10:33 PM
elwood's Avatar
Default Re: Break Caliper Help (TeamStitchEj1)
I figured it was a streach.
Found the s2 for 135$ shipped, and this sexy lady
wants 450$ for some ricer red nsx'ers.
Im going to have a hard time spending 450$ on a
car that dosnt even drive yet.
kulo
Suspension & Brakes
Jun 2, 2017 07:10 PM
Kennyjai
Mar 8, 2012 02:35 PM
MLRtime
Jun 26, 2008 01:42 PM
MLRtime
May 21, 2008 07:10 AM
TYPERman2001
Dec 26, 2007 09:33 AM
