Honda S2000 Honda S2000
Boosting an '05 w/ Lovefab GT35R
Old 11-27-2006, 02:42 PM
oni3's Avatar
Default Boosting an '05 w/ Lovefab GT35R
First I'd like to thank those who have helped me this far... I've decided on an '05 S2000 and for boost I'm going with the Lovefab GT35R turbo system. My next question is... What, if any modifications will be needed or recommended to have for this setup?
LoveFab SideWinder-GT1 manifold;
LoveFab SideWinder-GT1 3 inch downpipe;
LoveFab SideWinder-GT1 dump tube;
LoveFab Oil filter relocation, cooler assembly;
LoveFab Turbo manifold bracing system
LoveFab Turbo oil feed/return lines;
LoveFab inch Intake arm, with AEM filter;
Precision 750hp Intercooler, with mounting brackets;
2.5 inch Aluminum Charge piping, all clamps/couplers;
Garrett GT35R;
TiAL 44mm Wastegate;
TiAL 50mm BOV;
AEM EMS;
RC 750cc high-impedence injectors;
Walbro 255lph fuel pump;
Fuse box relocation tab;
All hardware, gaskets;
Old 11-27-2006, 07:07 PM
s2kdre's Avatar
Default Re: Boosting an '05 w/ Lovefab GT35R (oni3)
no mods needed, just dont go over 400whp on a stock motor.
Old 11-28-2006, 03:38 AM
oni3's Avatar
Default Re: Boosting an '05 w/ Lovefab GT35R (s2kdre)
What is the weekest link(s) that 400whp is the limit?
Old 11-28-2006, 04:25 AM
Miracle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oni3 &raquo;</TD></TR><TR><TD CLASS="quote">What is the weekest link(s) that 400whp is the limit?</TD></TR></TABLE>
The rear differential.
Old 11-28-2006, 05:17 AM
Francesco's Avatar
Default Re: Boosting an '05 w/ Lovefab GT35R (Miracle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miracle &raquo;</TD></TR><TR><TD CLASS="quote">
The rear differential. </TD></TR></TABLE>
Tranny and axles also.
Old 11-28-2006, 06:07 AM
LAS2K's Avatar
exedy stage 2 or 3 clutch.
Old 11-28-2006, 08:25 AM
oni3's Avatar
Default Re: Boosting an '05 w/ Lovefab GT35R (LAS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAS2K &raquo;</TD></TR><TR><TD CLASS="quote">exedy stage 2 or 3 clutch. </TD></TR></TABLE>
This was anticipated. However, since the subject came up... About how much ft-lbs/whp is the stock clutch good for?
Old 11-28-2006, 12:01 PM
evil vapor's Avatar
where's mase on this subject.
Old 11-28-2006, 12:33 PM
IrishAP1's Avatar
Well if you haven't bought yet, you might want to look into the inline pro kit. Seems alot of people have had major problems with the lovefab kit.
Old 11-28-2006, 02:38 PM
texx's Avatar
Default Re: Boosting an '05 w/ Lovefab GT35R (IrishAP1)
Don't worry to much about probs. with the kit. Most of the issues were with very early kits. I run the same set-up on my 05. Just a couple of things, the 2.5 in. charge piping is only listed because the driver side rad. fan gets in the way. I would reccomend running a koyo radiator with some low profile fans and do 3in. piping. If you do the uego upgrade it will pay for itself when it's time to tune and you won't have joe blow drilling and welding on your downpipe! You definetly need a clutch. also, a thermostat and vented hood will really help. ------ who is doing the install?-------
Old 11-28-2006, 02:55 PM
oni3's Avatar
Default Re: Boosting an '05 w/ Lovefab GT35R (texx)
Well... I was either going to install at JDMmotorsports and have it tuned by Jeff Evans of Evans Tuning or have Lovefab do it. Kit is $8500, but only $500 more if Lovefab installs & tunes. You can't really beat that.
The inline pro kit may perform well, but looks like trash IMO.
Old 11-28-2006, 06:21 PM
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IrishAP1 &raquo;</TD></TR><TR><TD CLASS="quote">Well if you haven't bought yet, you might want to look into the inline pro kit. Seems alot of people have had major problems with the lovefab kit.</TD></TR></TABLE>
Most problems are all do to the install, although I will admit that one guy complained about the overall quality of his Lovefab kit. I myself have heard nothing but good things regarding the quality of Lovefab, but I have heard the horror stories also. Personally I would never turbo the s2000.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oni3 &raquo;</TD></TR><TR><TD CLASS="quote">Well... I was either going to install at JDMmotorsports and have it tuned by Jeff Evans of Evans Tuning or have Lovefab do it. Kit is $8500, but only $500 more if Lovefab installs & tunes. You can't really beat that.
The inline pro kit may perform well, but looks like trash IMO.</TD></TR></TABLE>
Word, Im going to get my ITB's tuned at Evanas once I get them
Old 11-28-2006, 06:44 PM
oni3's Avatar
Default Re: Boosting an '05 w/ Lovefab GT35R (Francesco)
It's a good thing that I haven't purchaed yet because that still leaves me with the opportunity to change my mind.
Old 11-28-2006, 07:51 PM
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oni3 &raquo;</TD></TR><TR><TD CLASS="quote">It's a good thing that I haven't purchaed yet because that still leaves me with the opportunity to change my mind. </TD></TR></TABLE>
Why not go custom?
When I wanted turbo I wanted the lovefab manifold and turbo with the InlinePro FMIC and piping.
Old 11-29-2006, 07:07 PM
oni3's Avatar
It's a possablity.
How about exhaust systems for a tubo'd S2000? I'm sure this questions has come up 9,312 times... Once more can't hurt. I was thinking Toda or maybe Invidia, but I'm not sure how well these will work with FI. Anyone have any thoughts or suggestions?
Old 11-29-2006, 07:22 PM
Francesco's Avatar
If you want something off the shelf than you need to look into the AMUSE r1000 or the J's racing 70rr. Both systems are single header back exhaust.
If these arn't an option, you will need something made custom 3'' streight through.
Old 11-29-2006, 10:54 PM
bmoua's Avatar
i'd stay away from exedy...go with act...
Old 11-30-2006, 01:56 PM
texx's Avatar
Default Re: Boosting an '05 w/ Lovefab GT35R (bmoua)
Having Cody install it would be best. Then if you do have an issue, no problem. That's what I did. I drove about a 1000 miles one way but he was a 1000$ cheaper than anybody else. The guy put me up for 3 days free. plus I got to watch and help with everything. You get all your questions answered, pick out the pieces you like. Street tune and that ride home is great. Personally, I don't like someone installing my kit who is as familiar with it as I was. Then there like " you can't stay come back in two days".
Old 11-30-2006, 03:15 PM
oni3's Avatar
That's pretty awesome. Tho I can't say that I'm to thrilled about only having a street tune. I'll more than likely take it to Evans Tuning anyway.
Where can I find a J's or AMUSE exhaust?
Old 11-30-2006, 04:39 PM
texx's Avatar
Oh yea! You definately wont to have it tuned at a shop on a dyno, but cha gotta get that baby home.
Old 11-30-2006, 06:19 PM
Berner9's Avatar
Only reason people have been having problems cuase they are trying to install themselves. If im not mistaken cody is only selling it as a kit if he installs it(i beleive). Id go to s2ki and read up on it more. There is a lot more info there.
What ever you do good luck with it. I wish i had some more money to put one in mine.
Old 12-01-2006, 06:55 PM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua &raquo;</TD></TR><TR><TD CLASS="quote">
i'd stay away from exedy...go with act...</TD></TR></TABLE>
I have to disagree. I dont wana change the subject, but ACT makes some of the WORST clutches ever (IMO). I hate the pedal feel, I hate the quality, and i hate the overall vagueness between engaged and disengaged. Exedy, on the other hand, makes some of the best clutches ever (IMO). They're good enough to be OEM honda parts, and overall holding power isnt everything. Even turbo S2s arent really going to make a whole crap load of torque. The Exedy clutches are going to maintain stock feel very well, plus the feedback from the clutch is AWESOME. Back when i drove a civic, i replaced the OEM with an exedy aftermarket and it was probably the ONLY organic clutch i EVER liked. Granted this was a B series and front wheel drive...but it was an awesome over all product. So basically, Exedy FTW. ACT if you want the stupidest clutch ever.
Old 12-01-2006, 10:06 PM
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oni3 &raquo;</TD></TR><TR><TD CLASS="quote">That's pretty awesome. Tho I can't say that I'm to thrilled about only having a street tune. I'll more than likely take it to Evans Tuning anyway.
Where can I find a J's or AMUSE exhaust?</TD></TR></TABLE>
Ive been talking to Evans about my ITB's, this summer
PS: I got AMUSE exhaust, you need a hook up? PM me.
Old 12-02-2006, 01:24 PM
oni3's Avatar
Francesco - Thank you, but I'll pass. I'm leaning toward the J's right now. May I ask why you switched?
B serious - I to dislike ACT. I have a Clutch Masters FX100 in my Civic and like it a lot.
Old 12-02-2006, 04:54 PM
B serious's Avatar
yeah. Clutchmasters is another company that's got some really good product.
Quick Reply: Boosting an '05 w/ Lovefab GT35R
