Honda S2000 Honda S2000
The big question.... keep it N/A or implement forced induction
Old Jun 13, 2007 | 04:17 PM
Murrdog9000's Avatar
Default The big question.... keep it N/A or implement forced induction
What are your thoughts on modifying an s2000, keep it N/A and maybe put on individual throttle bodies or us forced induction
Old Jun 13, 2007 | 04:40 PM
papa5murf's Avatar
Default Re: The big question.... keep it N/A or implement forced induction (Murrdog9000)
Your car, you pick.
Old Jun 13, 2007 | 06:17 PM
Shy_GuyAP1's Avatar
I'd like to see another N/A killer, but make sure that you are making at least 120HP/L.
Old Jun 14, 2007 | 06:05 AM
lucky4586's Avatar
Default Re: (Shy_GuyAP1)
I would also like to see a NA killer... but on the other hand turbos are fun... as it was said already you car you pick
Old Jun 14, 2007 | 07:34 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
N/A=$$$$$$$$$
F/I= more for your $$$$$$
your pick!
Old Jun 14, 2007 | 08:28 AM
cmdr430's Avatar
what is your intended use for the car?
daily driver?
track use
autox?
these would greatly influence how i would modify my car.....
Old Jun 14, 2007 | 08:33 AM
Default Re: The big question.... keep it N/A or implement forced induction (cmdr430)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 &raquo;</TD></TR><TR><TD CLASS="quote">what is your intended use for the car?
daily driver?
track use
autox?
these would greatly influence how i would modify my car.....</TD></TR></TABLE>
daily driving...but id still want a sick car
Old Jun 14, 2007 | 08:36 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
daily driver?
track use
autox?
yes true but a proper sized turbo will work wonders on a S2K....
Old Jun 14, 2007 | 08:41 AM
cmdr430's Avatar
Default Re: The big question.... keep it N/A or implement forced induction (S@nt0s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">
yes true but a proper sized turbo will work wonders on a S2K....</TD></TR></TABLE>
i completely agree......
as long as it is properly installed/tuned.....
but, i still believe the best bang for the buck, w/ Reliability would be to change the final drive......
totally changes the car......which i am sure you know
Old Jun 14, 2007 | 08:42 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
totally changes the car......which i am sure you know</TD></TR></TABLE>
100% on the gearing.....
see the thigns is with people nowadays is that want XXX amount of #'s to see on a street car yet in reality its USELESS.....
i had a built LS-T 62-1 with all the fixins yet i drove it daily on only 10psi.. WHY? because that was all i needed on a daily basis....
Old Jun 14, 2007 | 08:56 AM
White .:R32's Avatar
So proper turbo size? You need a turbo to match the enging/rpm curve, so 35R, 30R might fall off too soon from what I've been told. Looking!
Old Jun 14, 2007 | 09:10 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: The big question.... keep it N/A or implement forced induction (White .:R32)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White .:R32 &raquo;</TD></TR><TR><TD CLASS="quote">
So proper turbo size? You need a turbo to match the enging/rpm curve, so 35R, 30R might fall off too soon from what I've been told. Looking! </TD></TR></TABLE>
fall off too soon? whoever told you that might have told you a 42R was perfect for a stock F20/22c on pump gas too right???
a large GT28 like a 82a/r might work but i would have ot look at the graph.... t3t4 50 trim would spool up fast and carry the power but start to fall off up top a bit.. but the torque will be high on it
Old Jun 14, 2007 | 11:13 AM
lucky4586's Avatar
gt30 or gt35 would be prefect for a 2.0L or 2.2L gt30 will spool fast and keep on kicking all the way to redline... gt35 is just one step up... look at the greddy turbo kit that has a small turbo and works great for a DD. Many people have them and are happy with the about 300whp they put out. the greddy is cheaper and is a full kit with everything you need. now on the other hand the comptec supercharger is also great and makes about the same hp. Both are great for a DD you really dont want much more then 300whp for a DD you just cant use it and it will get you in trouble!!! I also would like to add that going to a 4.56 gearing would be some thing i would look into if you feel you need a lower 0-60.
Old Jun 14, 2007 | 11:15 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: The big question.... keep it N/A or implement forced induction (lucky4586)
no it would not be PERFECT..... we are talking about a turbo for a Roadcourse based set up...
Old Jun 14, 2007 | 11:51 AM
Dark-s2k's Avatar
I think an na beast would be more fun.
Once inlinepro has perfected their 2.7l stroker I would say go for that.
If you want some 'cheaper' power then just go turbo and be done with it.
I like the idea of a 300rwhp engine with a side of nitrous. (DP 100shot to be exact)
Old Jun 14, 2007 | 12:31 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (Dark-s2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dark-s2k &raquo;</TD></TR><TR><TD CLASS="quote">I think an na beast would be more fun.
I like the idea of a 300rwhp engine with a side of nitrous. (DP 100shot to be exact)</TD></TR></TABLE>
100 shot isnt needed.....
Old Jun 14, 2007 | 12:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">fall off too soon? whoever told you that might have told you a 42R was perfect for a stock F20/22c on pump gas too right??? </TD></TR></TABLE>
I have a 3076 that I got for a 1.8t gti but it's diveded for the low redline in the vw. since I never put it on the car I was thinking of running it on the S2k but Jesse of AFI (my shop neighbor) suggested that the 30R would fall off around 72-7500, and after shifting @ 9000 it dropping to about 7500 between shifts that it would max out right at vtech.
Old Jun 14, 2007 | 01:05 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
I have a 3076 that I got for a 1.8t gti but it's diveded for the low redline in the vw. since I never put it on the car I was thinking of running it on the S2k but Jesse of AFI (my shop neighbor) suggested that the 30R would fall off around 72-7500, and after shifting @ 9000 it dropping to about 7500 between shifts that it would max out right at vtech. </TD></TR></TABLE>
not too sure about it falling off so soon
Old Jun 14, 2007 | 01:17 PM
lucky4586's Avatar
3076 is what Im looking at for my evo and it is perfect for anyone that is using the car for everyday and will be putting out less then 400hp now that is on a evo and a f20/f22 will not need that much more is any cfm so it should work great. gt35 would be a better choice if you going for big numbers but since you said that you are looking at a NA setup or FI that kinda told me you not looking for big numbers and while NA whp what 300 is about all you could get out of it so im keeping that in mind. How much money do you want to spend is a big factor in what you do so ask yourself how much do you want to spend... a 400+ whp setup will run you a good 6-7k easy with fuel management. The more i think about it because i am looking at buying a s2k soon ... I would do simple greddy turbo kit or the comptech supercharger and 4.56 gearing.. easy 300whp ..not to much not to little and should smack down a 0-60 in what 4.5 secs or so" if you hook up"
again you car you pick what you want to do but this has made me think about what im going to do... i wanted big power but i dont want a dyno queen. I just want a car i can afford to drive and have fun with it.. thats why I stop at ~350 whp on my evo which is my winter car and i drive it in the snow...
Old Jun 14, 2007 | 01:23 PM
Dark-s2k's Avatar
Default Re: (S@nt0s)
I meant a 300rwhp 2.7l stroker + a 100shot
oh its needed, its definitely needed.
Old Jun 14, 2007 | 01:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lucky4586 &raquo;</TD></TR><TR><TD CLASS="quote">again your car you pick what you want to do but this has made me think about what im going to do... i wanted big power but i dont want a dyno queen. I just want a car i can afford to drive and have fun with it.. thats why I stop at ~350 whp on my evo which is my winter car and i drive it in the snow... </TD></TR></TABLE>
350whp is right about were I'd like it to be. I can't think of a more fun car to drive with that power range(for the $$). I've done the big # thing on my vw .:R32 and I'm not a fan of breaking to many parts on a weekly driver.
Old Jun 14, 2007 | 01:36 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
yes a GT30 is nice on a EVO.. i have VIII myself..... however the 4G63 does not flow like a N/A F20/22.. however with the right staged wheel/ar/trim it will carry itself well into where you need it to be...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dark-s2k &raquo;</TD></TR><TR><TD CLASS="quote">I meant a 300rwhp 2.7l stroker + a 100shot
oh its needed, its definitely needed. </TD></TR></TABLE>
stock on a 100 shot with 4.7's....
Old Jun 14, 2007 | 02:40 PM
-iLLuZioN-B18C1's Avatar
watch out for the ITBs...make srue you know what you are getting into. lotssss of tuning required for it. and the way you tune it for summer....will more than likely need a different tune in say...fall/winter
Old Jun 15, 2007 | 12:57 AM
WowOzYouRock's Avatar
Default Re: The big question.... keep it N/A or implement forced induction (-iLLuZioN-B18C1)
i wanna built me an S2000 with everything on it.. supercharged ITB w/ turbo and still has header...
Old Jun 15, 2007 | 06:25 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: The big question.... keep it N/A or implement forced induction (FR-MOB: Jerk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Jerk &raquo;</TD></TR><TR><TD CLASS="quote">i wanna built me an S2000 with everything on it.. supercharged ITB w/ turbo and still has header...
with a GT-R emblem on the trunk!
