Honda S2000 Honda S2000
back glass
Old Mar 25, 2010 | 09:44 AM
JDMxNguyeN's Avatar
Default back glass
how do i change from the plastic window to glass window? first 12 hour of owning a s2k.....
Old Mar 25, 2010 | 10:05 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: back glass
buy a new top with the glass installed... gonna prolly take u 12 hours to do...
Old Mar 25, 2010 | 10:19 AM
camoy's Avatar
yeah that is the only way and it is not fun. If you can get one with the frame intact and that will make install a little easier. Welcome to owning an S
Old Mar 25, 2010 | 03:46 PM
JDMxNguyeN's Avatar
how much is it to do the back glass?
Old Mar 25, 2010 | 06:38 PM
DirtyS2K's Avatar
The frame is one with the hardtop?
Is the glass really worth it if you aready have the soft?
Old Mar 26, 2010 | 11:04 AM
White Smoke's Avatar
i my honda
Global Mod
You have to buy a new top. You can get an 03+ OEM top but you will need the 03+ frame as well. Or you can buy a robins top (or other aftermarket top) that works with the old style frame.
Old Mar 27, 2010 | 03:34 PM
JDMxNguyeN's Avatar
i only interested in the mugen top.... thanks
Old Mar 30, 2010 | 07:36 AM
camoy's Avatar
OK I am confused are you asking about how to switch to a glass window in the OEM soft top or an aftermarket hardtop? My original post pertains to switching from the plastic window in an OEM soft top. To do that you would need a 03+ soft top and 03+ frame, and preferably they be together. Now if you are asking about a aftermarket HT then this info does not apply.
Old Mar 30, 2010 | 10:08 AM
The Black Pearl's Avatar
something like this works great if you are referring to a soft top
http://www.topsonline.com/index.php?CarmodelID=746000
Old Mar 31, 2010 | 08:00 AM
i my honda
Global Mod
You need to replace the window in your mugen hardtop, is that what you are saying? If so go to your local glass place and have them make a custom one for you.
Old Mar 31, 2010 | 12:40 PM
bigmacnfries's Avatar
have you been away smokey?
Old Mar 31, 2010 | 12:55 PM
esoterEK..'s Avatar
lol..wtf.
Old Apr 8, 2010 | 08:48 PM
JDMxNguyeN's Avatar
sorry i mixed up the threads ahahah
Old Apr 8, 2010 | 08:50 PM
JDMxNguyeN's Avatar
wat i really want to do is... change my back plastic out for back glass top.... and then get the hard top... thats the plan as of right now...
Old Apr 9, 2010 | 04:40 AM
camoy's Avatar
Then as stated above the easiest way is to get a soft top with glass and frame and swap it out. The reason why you want the frame is it makes installing the top much easier, no rivets to drill out and stuff to cut. Though it makes it more expensive to ship so try to find it local. Luckily you are in CA so a local top should be an easy find just go to S2KI and search the For Sale. Also if you want the rear defogger to work you will need to buy the parts for that too.
Old Apr 9, 2010 | 07:39 PM
JDMxNguyeN's Avatar
ok cool thanks got it down now...
Old Apr 9, 2010 | 10:53 PM
S2K-APWON's Avatar
Yup, try and get a glass soft top attached to a frame, will knock off 6 hours in your installation, i know ive done it. All you have to do is take out the seats and most of the rear panels and it will bolt right up. They can go from 700 to 900 dollars used depending on condition.
pliskin679
May 23, 2010 06:04 PM
SPOOLINmatt
Apr 28, 2009 08:12 AM
dnc8203
Dec 3, 2007 06:09 PM
Wirelesseffect
Honda S2000
Feb 2, 2006 11:25 PM
SiMateoAko
12
Jul 23, 2005 09:05 PM
