99 honda s2000 engine cuts out at 7000RPM
Engine is cuting out on my S . Car is warmed 3 bars, did the map wack, cleaned the IACV.......... oil is full. Replaced the Vtech solonoid gasket and everything was fine. Just all of a sudden it started doing this..... MAP sensor is also cleaned ... the place it goes in is also cleaned. Read all the forums every where..... did everything suggested ..... Car is stock with only 62K miles. ..
please Help
appreciate any info ...
please Help
It can be either a problem with air, fuel, or spark. You should try and check to see which area your problem is occurring. I had a similar issue with my engine cutting out completely at 6k RPM, and it turned out I had a bad coil pack plug on the harness that was causing an intermittent/weak spark in one cylinder.
