Honda S2000 Honda S2000
2.5 stroker kit
Old Jan 27, 2005 | 12:02 PM
G'd_up's Avatar
Default 2.5 stroker kit
does anyone have the 2.5 stroker kit or the inline pro turbo kit on their S2? Just wanna know how they like it and if they have 1/4 mile times
Old Jan 27, 2005 | 12:21 PM
bryant's Avatar
Default Re: 2.5 stroker kit (G'd_up)
do a search its been talked about in this forum before with pics of dyno plots and all for you.
Old Jan 27, 2005 | 12:28 PM
Nishant's Avatar
Default Re: 2.5 stroker kit (Bryant)
https://honda-tech.com/zerothread?id=1093107
Old Jan 27, 2005 | 12:32 PM
BOOSTEDS2K's Avatar
Default Re: 2.5 stroker kit (Nishant)
only one person dose and he went 13.7 or 13.6 but he had a bad launch
Old Jan 27, 2005 | 12:41 PM
G'd_up's Avatar
Default Re: 2.5 stroker kit (BOOSTEDS2K)
tried a search; 2.5 stroker kit,2.5, etc. nothing comes up
Old Jan 27, 2005 | 01:49 PM
rastropovitch
Guest
Posts: n/a
165 Stock??? jezze
Schu
Old Jan 27, 2005 | 06:46 PM
papa5murf's Avatar
Default Re: 2.5 stroker kit (MSchu)
ehhh i'm not going to explain all this again...... just click that link nishant has up in this post..
Old Jan 27, 2005 | 07:47 PM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G’d_up &raquo;</TD></TR><TR><TD CLASS="quote">tried a search; 2.5 stroker kit,2.5, etc. nothing comes up</TD></TR></TABLE>
look at the link i posted above. if thats not enough, go to s2ki.com and search for it
Old Jan 27, 2005 | 07:48 PM
VtecBlissS2k's Avatar
Default Re: 2.5 stroker kit (03s2kblue)
i remem a post about a 12 second s2k... most said it was impossible w/o boost...
but with a 13.5 w/ stroker kit on a bad launch....
ITB's, EMS...maybe drag radials, sounds very attainable...
anyone else care to comment on my thoughts?
Old Jan 27, 2005 | 07:49 PM
Nishant's Avatar
Default Re: 2.5 stroker kit (VtecBlissS2k)
well 13.7 is doable stock so with stroker kit, i could see 13-13.1 easily maybe even lower
Old Jan 27, 2005 | 07:50 PM
revhi's Avatar
Ill believe it when I see it. All Ive seen so far are if's.
Old Jan 27, 2005 | 07:52 PM
Nishant's Avatar
Default Re: (revhi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhi &raquo;</TD></TR><TR><TD CLASS="quote">Ill believe it when I see it. All Ive seen so far are if's.</TD></TR></TABLE>
go buy me the kit and i will do it
Old Jan 27, 2005 | 07:55 PM
Default Re: (revhi)
if someone can make a N/A NSX thatll run 12.5's with bolt-ons (w/ no ITBs)..
NSX=280hp?/3200lbs
S2K=240hp/2700lbs..
seems more and more possible..
and when i do run 12's, ill be sure to post
Old Jan 27, 2005 | 08:02 PM
revhi's Avatar
Default Re: (VtecBlissS2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecBlissS2k &raquo;</TD></TR><TR><TD CLASS="quote">if someone can make a N/A NSX thatll run 12.5's with bolt-ons (w/ no ITBs)..
NSX=280hp?/3200lbs
S2K=240hp/2700lbs..
and when i do run 12's, ill be sure to post </TD></TR></TABLE>
Tell me when your ready to do it ill come down and watch. One big thing with your NSX theory. Its a 6 with torque which = better 60' times.
Old Jan 27, 2005 | 08:03 PM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecBlissS2k &raquo;</TD></TR><TR><TD CLASS="quote">i remem a post about a 12 second s2k... most said it was impossible w/o boost...
anyone else care to comment on my thoughts?</TD></TR></TABLE>
if you read that thread i think i mentioned the same exact thing as you just mentioned.... it's well possible and actually rather easy if you have those things....
Old Jan 28, 2005 | 06:49 AM
brasilracing's Avatar
NSX=280hp?/3200lbs
S2K=240hp/2700lbs..
Possible, but remember that the NSX is mid-engined.
Old Jan 28, 2005 | 08:52 AM
revhi's Avatar
Default Re: (brasilracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brasilracing &raquo;</TD></TR><TR><TD CLASS="quote">Possible, but remember that the NSX is mid-engined. </TD></TR></TABLE>
Shouldnt make that much of a difference in1/4 mile times. Besides technically the S is also mid engine.
Old Jan 28, 2005 | 09:31 AM
papa5murf's Avatar
Default Re: (revhi)
Shouldnt make that much of a difference in1/4 mile times. Besides technically the S is also mid engine.</TD></TR></TABLE>
yep... no difference is it's a mid engine...
keithhofmann
Honda S2000
14
Jan 30, 2008 08:17 PM
malubawla
19
Nov 22, 2005 08:55 AM
ATS*Mark
Aug 8, 2004 11:40 AM
civic 90
Jun 14, 2004 11:41 PM
96GetSetRev
Apr 20, 2004 12:05 PM
