Honda S2000 Honda S2000
06 MISFIRE PROBLEM PLEASE HELP!!!!!!
Old Feb 26, 2008 | 12:15 PM
FAMOUSAUTOSPORTS's Avatar
Default 06 MISFIRE PROBLEM PLEASE HELP!!!!!!
HI EVERYONE HERES THE PROBLEM. WE JUST GOT DONE INSTALLING A BUDDY CLUB HEADER HIGH FLOW CAT AND MUGUEN EXHAUST SYSTEM. THE CAR ALSO HAS A FUJITA AIR INTAKE. IVE DRIVEN THE CAR FOR A COUPLE OF DAYS AND THE CAR HAS RUN GREAT. NO PROBLEMS. I DROVE IT AROUND THIS MORNING AND IT WAS FINE. I BROUGHT IT BACK AND PUT SOME GAS IN IT. THE TANK WAS ALLREADY HALF FULL. TOPED IT OFF TO GO TO DYNO FOR REFLASH. AFTER TOPING OFF GAS DROVE ABOUT A MILE AND CAR STARTED TO MISFIRE. THE CHECK ENGINE LIGHT STARTED FLASHING AND THE VAS LIGHT AND ALSO THE EXCLAMATION MARK STARTED TO FLASH. THE CAR STARTED TO RUN HORRIBLE. GOT IT BACK TO THE SHOP. PULLED OFF THE SPARK PLUGS. ALL LOOK FINE THE ONLY THING I NOTICED WAS THAT THE CYLINDER 4 PISTION LOOKED MORE BLACK THAN THE OTHERS. BEFORE I PULLED THE SPARK PLUGS OUT I CLEARED THE COMPUTOR AND LEFT THE BATTERY OFF FOR A LITTTLE BIT. PLUGED EVERYTHING BACK IN AND IT STILL DIDNT FIX IT. IF I REVED THE MOTOR A LITTLE BIT IT WOULDNT HESISTATE TO MUCH BUT AT IDLE IT STRUGGLED TO STAY ON. ANY THOUGHTS PLEASE HELP THANKS!!!!!
Old Feb 26, 2008 | 12:19 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: 06 MISFIRE PROBLEM PLEASE HELP!!!!!! (FAMOUSAUTOSPORTS)
1. turn off the capslock
2. learn how to spell
3. change your name to FAILUREAUTOSPORTS
Old Feb 26, 2008 | 12:22 PM
Black S2K's Avatar
um why dont you pull the codes ur cel is throwing and find out the problem????
btw How do u like the buddy club header?
Old Feb 26, 2008 | 12:24 PM
sorry i was typing really fast to try and figure this problem out. and your humor is breath taking. thanks for your help.
Old Feb 26, 2008 | 12:28 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: (FAMOUSAUTOSPORTS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FAMOUSAUTOSPORTS &raquo;</TD></TR><TR><TD CLASS="quote">and your humor is breath taking. thanks for your help. </TD></TR></TABLE>
as is your stupidity. thanks for the waste of bandwidth.
is says multiple misfire and o2 sensor but i think the o2 came up from the misfire. not sure where it went wrong car was runnig on point filled it up with gas and then problems. the car only has just over 6000 miles on it. the buddy club header is awesome very lightweight. i got a great deal on them. im planning on posting the dyno numbers when im done at the dyno with it. i will let you know if you like.
Old Feb 26, 2008 | 12:31 PM
Black S2K's Avatar
yea do it.
Maybe the o2 code is from the highflow cat make a o2 fix theres a diy on how to do it in the diy sticky thread.
And I cant help you with the misfire i have no experience with that kinda problem.
Old Feb 26, 2008 | 07:28 PM
joey1320's Avatar
Default Re: (Black S2K)
lot replies and not one serious bit of help...
check the alcohol content in the fuel buddy... the problem started right after the new gas went into the tank so why not start there...
do you know how to?
heres a link:
http://www.ehow.com/how_214319....html
btw you want to have less than 10% mixture of alcohol in your fuel. anything more and it can damage your fuel injectors, lines and cause misfires. also theres no way that the parts you installed could cause serious misfire issues.
Good Luck!
Old Feb 27, 2008 | 06:20 PM
vpforeva's Avatar
New User
Default Re: (joey1320)
you didnt inadvertently put diesel in the car did you? lawl
Old Feb 27, 2008 | 06:30 PM
joey1320's Avatar
Default Re: (vpforeva)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vpforeva &raquo;</TD></TR><TR><TD CLASS="quote">you didnt inadvertently put diesel in the car did you? lawl</TD></TR></TABLE>
lol yeah that would be funny
Old Feb 28, 2008 | 04:07 AM
HondaKyle's Avatar
I had this problem i just cleared it and it never came back....
Old Feb 28, 2008 | 05:25 AM
Techno Tonis's Avatar
Default Re: 06 MISFIRE PROBLEM PLEASE HELP!!!!!! (HondaKyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle &raquo;</TD></TR><TR><TD CLASS="quote">I had this problem i just cleared it and it never came back....</TD></TR></TABLE>
WTF?
your car misfired....and you just... RESET THE ECU???
that's pretty stupid even for you kyle...
Old Feb 28, 2008 | 05:29 AM
[QUOTE=FAMOUSAUTOSPORTS]HI EVERYONE HERES THE PROBLEM.QUOTE]
No clue where to begin.
I mean... If it's an 06...I don't know what to tell you.
Oil leak? check all of your bolts underneath...make sure nothing is leaking...do you have any gauges hook up?
Old Feb 28, 2008 | 12:51 PM
A_P_1's Avatar
Damn dude! Think before you do it! Luckily its not that bad! Good Luck!
Old Feb 28, 2008 | 12:57 PM
HondaKyle's Avatar
Default Re: 06 MISFIRE PROBLEM PLEASE HELP!!!!!! (Techno Tonis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Techno Tonis &raquo;</TD></TR><TR><TD CLASS="quote">
WTF?
that's pretty stupid even for you kyle... </TD></TR></TABLE> It did it because it was really cold out...only happen once in two cylinders to
Moaltar
Honda Civic (2001 - 2005)
Oct 17, 2013 11:39 AM
RobRyan0927
Dec 2, 2010 09:34 AM
SIRIUS
May 21, 2005 09:14 AM
ATS*Mark
Sep 8, 2004 02:52 AM
Black_eh2
Honda S2000
Apr 12, 2003 07:39 PM
