WTB: Throttle Position Sensor
Old Feb 18, 2003 | 03:54 PM
ludedudesi's Avatar
Default WTB: Throttle Position Sensor
ok my idle has been messed up for about 2 months now. people are now telling me its the tps causing it so does anyone have one for sale for a reasonable price? thanks
Old Feb 18, 2003 | 05:37 PM
ludedudesi's Avatar
Default Re: WTB: Throttle Position Sensor (ludedudesi)
anyone??
Old Feb 18, 2003 | 06:28 PM
3gLudeH22A's Avatar
Ive got 3 of them laying around... 20 bucks and you can have one of them.
Old Feb 18, 2003 | 06:41 PM
ludedudesi's Avatar
Default Re: WTB: Throttle Position Sensor (3gLudeH22A)
Hmm that sounds good. where are you located at??
Old Feb 18, 2003 | 06:50 PM
kb58's Avatar
Banned
I thought the TPS was an integral part of the throttle body, one that can't be removed. Given that, I might be interested in one also.
Old Feb 18, 2003 | 06:58 PM
ludedudesi's Avatar
Default Re: WTB: Throttle Position Sensor (kb58)
well actually i think it can be removed with a hex head screwdriver or something. anyways you just cant buy the tps from honda, you have buy the WHOLE throttle body which is a nice amount of pocket change. 380 bucks!!
Old Feb 18, 2003 | 07:01 PM
Cottonwoodz's Avatar
I got $380 bucks it is not your TPS senser, that has your idel all screwed up.
Old Feb 18, 2003 | 07:13 PM
3gLudeH22A's Avatar
Default Re: WTB: Throttle Position Sensor (Cottonwoodz)
Well, all I did was take my TB to a friend of mine and had him cut some grooves big enough to put a flat head in it and screw them out, its a good idea too. But if you need them i got them
Im in GA BTW
Old Feb 18, 2003 | 07:22 PM
ludedudesi's Avatar
Default Re: WTB: Throttle Position Sensor (gr8gribbs)
Checked for vacuum leaks, the thermal valve is bypassed using a gasket for the coolant bypass mod, replaced radiator to make sure not air was in the coolant system, replaced a new IAC valve. give me some more things that would cause the idle to surge
Old Feb 18, 2003 | 07:35 PM
First, explain how and when your idel is acting up. That will help alot
Old Feb 18, 2003 | 07:50 PM
Que_Lude's Avatar
Yeah, I'm a little hesitant to remove the Thermal valve and plate it over due to the osilating idle. I have the IAC bypassed, and my idle still wonders a little.
You might want to put back your thermal valve and see if it goes away...
Old Feb 18, 2003 | 07:56 PM
ludedudesi's Avatar
Default Re: WTB: Throttle Position Sensor (Que_Lude)
Well whenever i start my car is when it idles the lowest. around 1000 but when it starts warming up it idles at like 1300 and drops to 1000 and does it until im in gear and moving. It also does it when the clutch is pressed in and its idling while cruising. i have the tps unhooked right now and it just idles around 1700 without the surging. Stop the surging!!
Old Feb 18, 2003 | 08:13 PM
ludedudesi's Avatar
there was and may still be one in a auction on ebay. it was bored 66mm but i dont think i would benefit from it.
Old Feb 18, 2003 | 08:48 PM
ludedudesi's Avatar
any more input on this would be great.
Contender25
Nov 27, 2007 03:29 AM
nutball72
Nov 11, 2006 07:14 PM
revolt_allmotor
Sep 14, 2004 12:26 AM
Inaniac
Oct 21, 2002 12:34 AM
evo
Apr 9, 2002 09:39 PM
