wiring the iab
Old Oct 11, 2004 | 09:12 AM
Monkey Fing a Coconut's Avatar
Default wiring the iab
for the iab solenoid, the pink goes to the ecu which is easy enough (pin a17 i believe), but i gotta run a blk-yel to the ELD, how do i go about wiring it into the ELD???
thanks
Old Oct 11, 2004 | 11:25 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: wiring the iab (twistedbydezign)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twistedbydezign &raquo;</TD></TR><TR><TD CLASS="quote">for the iab solenoid, the pink goes to the ecu which is easy enough (pin a17 i believe), but i gotta run a blk-yel to the ELD, how do i go about wiring it into the ELD???
thanks</TD></TR></TABLE>
You can splice that wire into any other blk-yellow wire. It is a switched ignition wire and all others in your harness are the same. Or run it to any switched ignition source.
Old Oct 11, 2004 | 01:20 PM
Default Re: wiring the iab (cb7-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb7-R &raquo;</TD></TR><TR><TD CLASS="quote">
You can splice that wire into any other blk-yellow wire. It is a switched ignition wire and all others in your harness are the same. Or run it to any switched ignition source.</TD></TR></TABLE>
that makes it so much easier, ill just run it to the evap purge control solenoid or the egr control solenoid, both have easy access blk-yel wires (that actually merge into the same wire)
thanks
IGGY
Oct 10, 2006 09:46 AM
hondaboy90
Mar 28, 2006 02:02 PM
91sleeper
Mar 17, 2005 07:04 AM
AL ASPIRATED
Mar 29, 2004 08:22 PM
89sib16
Mar 3, 2004 02:34 AM
