Vtec oil usage?
Old Apr 17, 2007 | 10:33 AM
Dr Wylee's Avatar
Default Vtec oil usage?
Hey folks new to the forum,
I recently had a JDM H22a swapped and it seems that between oil changes it is drinking about a quart of oil.. it doesnt appear to be burning it [that i can smell or see during idle], and i dont see any leaks on the ground or along oil pan/engine area
however i did infact read somewhere before coming here that vtec when it engages "naturally drinks" oil? my prior experiance tells me that oil loss that is not coming from leaks is being burned due to bad valve seals n what not.. should i be looking to replace them or is this all normal?
Old Apr 17, 2007 | 10:37 AM
slammed95lude's Avatar
Default Re: Vtec oil usage? (Dr Wylee)
a full quart seems excessive but there is a consumption issue with v-tec motors. nothing to worry about just check your oil when you fill up tour tank and there should be no worry's. whatever you do don't let the oil level get to low and then engage v-tec.
Old Apr 17, 2007 | 10:39 AM
NirVTEC's Avatar
Just keep an eye on it. My old motor was going through 3qt/3000miles before its demise.
Check your oil!!!!!!!!!!!!!!! That a top Rule for VTEC owners!
Old Apr 17, 2007 | 10:42 AM
94GSRCivic's Avatar
Default Re: Vtec oil usage? (NirVTECn2o)
^ x2.
Old Apr 17, 2007 | 11:02 AM
Dr Wylee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NirVTECn2o &raquo;</TD></TR><TR><TD CLASS="quote">Just keep an eye on it. My old motor was going through 3qt/3000miles before its demise.
^that scares me (i dont want my 3k investment to die so soon ) but if its normal you fellahs say then i believe you i never let it get below half a quart low at a time.. although on break i just looked at the left side of the head where the sensors are screwed in and noticed that there appears to be some spray of oil there.. is this maybe where the oil is going?
Old Apr 17, 2007 | 11:58 AM
that could be, check your v-tec solenoid o-ring, be very careful while handling it.
Old Apr 17, 2007 | 01:08 PM
GtechPro's Avatar
Also check for leaks at the valve cover gasket and oil pan.
That's not that bad. Just make sure to keep an eye on it, and keep a spare qt of oil in the car.
My previous Prelude did the same thing and when I switched to 5W20 Mobil1 synthetic oil, it stopped. Same with my TypeR motor.
Old Apr 17, 2007 | 02:29 PM
Dr Wylee's Avatar
Default Re: (GtechPro)
Yea the spray appears to be on the lower end of the head whre the head meets the block i think theres an oil sensor of some kind there and thats where the spray appears to be.. could that hose* if thats what it is.. be bad? or the sensor all together? also.. should i try switching to synthetic then?
Old Apr 18, 2007 | 04:36 AM
shrirag's Avatar
at least you guys didn't burn 5 qts in liek about 1000 miles .. oh i can't wait for my swap!
Old Apr 18, 2007 | 10:39 AM
GtechPro's Avatar
Default Re: Vtec oil usage? (shrirag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shrirag &raquo;</TD></TR><TR><TD CLASS="quote">at least you guys didn't burn 5 qts in liek about 1000 miles </TD></TR></TABLE>
Hahaha now that's called oil burnage! LOL
Old Apr 18, 2007 | 08:21 PM
kulrevon's Avatar
Default Re: Vtec oil usage? (GtechPro)
or leakage. I lost 3qts in 20 miles. haha damn balancer seal..
I would say a qt every oil change is normal for the h22. especially if you engage vtec a lot.
Old Apr 18, 2007 | 08:27 PM
sivikvtec's Avatar
Default Re: Vtec oil usage? (kulrevon)
honda says that the car is within mechanical limits at 1qt/1000 miles.
its fine.
Old Apr 18, 2007 | 09:21 PM
prelude_h22vtec's Avatar
Default Re: Vtec oil usage? (sivikvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sivikvtec &raquo;</TD></TR><TR><TD CLASS="quote">honda says that the car is within mechanical limits at 1qt/1000 miles.
its fine.</TD></TR></TABLE>
x2 i just make sure to check my oil at least 3 times per week
when i change oil i buy 7 or 8 quarts
Old Apr 19, 2007 | 02:23 PM
Dr Wylee's Avatar
Default Re: Vtec oil usage? (prelude_h22vtec)
excellent this is good information. I feel a little better looking at it under the light of the manual. Im still gonna have a look at that sensor on the left side of the head though i think somethings gone wrong there or going. Thanks again for the common knoweledge folks
integrawow
Dec 6, 2009 04:58 PM
BLU CIVIC
Dec 4, 2008 04:41 AM
B18C-YA!
28
May 2, 2006 10:52 AM
da9driver
24
Aug 25, 2005 01:00 PM
