Vacuum system hose sizes?
I want to replace all of the hoses in the vacuum system as most of them are old and brittle. I wanted to know if anyone knew off hand what the sizes were for the hoses with the exception of the stock air intake hoses. From what I can recall the majority of the hoses are the same diameter, only a few are different.
I think they are a mix of 4, 6, and 10 mm.
Thanks in advance!
Modified by busyychild at 7:51 PM 3/27/2007
Thanks in advance!
Bringin this one back real quick.
How high does the quality have to be for vac hose. I bought some hose the other day but it feels really weak(kinda soft) to the point I can squeese it and block the hose. Just wondering if theres gonna be any problem with this, I'm thinking that under load I might have some problems.
Anyone have any input?
If it's made for use a vacuum hose it will be fine. It may not last as long as silicone hose (for example), but it should work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">If it's made for use a vacuum hose it will be fine. It may not last as long as silicone hose (for example), but it should work.</TD></TR></TABLE>
It is vacuum hose but I'm just not sure how good the quility has to be to be able to hold up under load. I haven't had any problems so far but I think I might just buy something a bit better just to be safe.
Any idea where to buy good quality hose online?
I HIGHLY reccomend http://www.hosetechniques.com. Probably not the cheapest, but they have great service and very good quality hose. I've been buying stuff from them for years...
You can a universal silicone hose assortment for $60
