type s cams!!
Old May 1, 2002 | 11:09 PM
aeolus's Avatar
Default type s cams!!
Ive heard of people having bad experiences with these cams.Do these cams need better springs other than the stock ones?If my math is good,a 12.2mm lift should be around .480 " for the intake,and the 11.2mm for the exhaust should be about .440".....right??Anyone here use them with good results???
Old May 2, 2002 | 05:39 AM
BoM's Avatar
BoM
Default Re: type s cams!! (aeolus)
get some portflow valvesprings and retainers.
Old May 2, 2002 | 09:04 AM
aklucsarits's Avatar
New User
The problem with the TypeS cams is that the valve angle is very different on the TypeS head compared to the regular H22a head. At least 2 people have confirmed and documented excessive wear and damage to the cams and rocker arms after only 2000-4000 miles of use. One of them had his cams reprofiled by Endyn after discovering the damage. He did not have the same wear issues after the reprofiling.
I would not recommend using the TypeS cams in a US H22a head.
Andrew
Old May 2, 2002 | 09:13 AM
BoM's Avatar
BoM
Default Re: type s cams!! (aklucsarits)
my friend has type S cams with a portflow head, no wear as of now.
takes it to 8k
Old May 2, 2002 | 09:51 AM
New User
Default Re: type s cams!! (BoM)
takes it to 8k
When was the last time he pulled the head to check the cam surfaces and rockers?
Alot of people run TypeS cams and have no operational problems. But very few people inspect the head after it's been put back together and run for a while...
Andrew
Old May 2, 2002 | 10:38 AM
migo's Avatar
New User
Exactly...
Old May 2, 2002 | 03:28 PM
BoM's Avatar
BoM
Default Re: type s cams!! (D.specs)
last month
its now 6 months now.
Old May 2, 2002 | 04:16 PM
aeolus's Avatar
So that would mean that the type s head casting may be different.maybe the combustion chamber angles may be different?Different ratio rocker arms??
[Modified by aeolus, 1:17 AM 5/3/2002]
Old May 2, 2002 | 05:52 PM
New User
Yes, the head casting itself is a different part. On the TypeS head, the valve seats are at a 45 degree angle. On a regular H22a head, they sit at 60 degree angles.
http://asia.vtec.net/beystock/honda/preludes/
Andrew
Old May 2, 2002 | 09:30 PM
aeolus's Avatar
Ah ha,i thought so.Its no wonder they can use such a high compresion piston...if thats the case,then the type s piston in a older head might have a different compression than the type s !!!Things that make you go Hmmmmm
Old May 2, 2002 | 11:52 PM
JDMTypeS's Avatar
New User
i have type s cams and had them in about 8500 miles now,(car has 39000), and i drive my car pretty hard. I do have Type S valve Springs, and retainers though. Will this solve the problem? do i need to worry??
Old May 3, 2002 | 12:43 AM
aeolus's Avatar
Default Re: type s cams!! (JDMTypeS)
did you see any big differences between the type s springs and the stock ones???
2fastGSR
Feb 12, 2009 10:15 AM
SiR-T
Oct 16, 2006 08:40 PM
c1civic
Dec 4, 2003 12:25 PM
blacklude
Oct 23, 2002 11:36 AM
H22CIVIC
Jun 16, 2001 12:05 AM
