turbo
Old Jul 12, 2004 | 02:25 PM
prelude61's Avatar
Default turbo
do i have to lower my compression level to run turbo cuz ma car is running a 10.6:1 ratio.
Old Jul 12, 2004 | 03:54 PM
grappler's Avatar
Default Re: turbo (prelude61)
You should lower your compression if you want to run boost over 6-8psi. Although with great tuning and management you can run over that, I have heard of people running 9-12 psi. But to be safe and feel a little more at ease running double digit boost, block build up is recommended. An ideal compression is 9:1, anywhere from 8.4 to 9.5 is good(the lesser gives you more range to work with, the higher gives you better response in city driving and low or no boost times.
Search! for more info, find the turbo prelude pages!...
Peace
Old Jul 12, 2004 | 04:44 PM
h22 civic's Avatar
Default Re: turbo (grappler)
your good up[ to 9 psi
Old Jul 12, 2004 | 05:54 PM
Kal's Avatar
Kal
Default Re: turbo (h22 civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">your good up[ to 9 psi</TD></TR></TABLE>
that is if your engine is not dying...
Old Jul 12, 2004 | 05:57 PM
Pr0jektLude's Avatar
Default Re: turbo (Kal)
and with 9 psi...wont be so safe so if its not dying it will be. The most id go with is 8 if that
jdjustme
Mar 9, 2007 01:05 PM
b18sihatch
Aug 16, 2006 10:01 AM
Coppertop
Aug 25, 2005 12:18 PM
dragteg
Oct 20, 2003 07:17 PM
*Boostwerks*
Jun 1, 2002 01:24 PM
