H23 help
Old Apr 24, 2003 | 12:08 PM
Peters1983's Avatar
Default H23 help
my friend has a 92 Prelude Si with a broken timing belt. I would like your opinions on what to rebuild it with. right now it is sitting with at least 4 bent valves and I have no clue what the pistons look like. any help or opinions are greatly appreciated.
Old Apr 24, 2003 | 12:24 PM
Greyout's Avatar
Default Re: H23 help (Peters1983)
after you have a clue what the pistons look like, you will have an idea if its even possible.
valve could have broken and been bounced around inside for a bit.
Old Apr 24, 2003 | 01:04 PM
Elkins911's Avatar
Default Re: H23 help (JDM LUDE)
you sure that the valves are bent? i thought that h23 was a noninterference motor
Old Apr 24, 2003 | 01:14 PM
lewd43's Avatar
Default Re: H23 help (Elkins911)
its an interference motor, my timing belt snapped while coming to a stop in neutral and i bent all the valves in the 2,3,and 4 cylinders
Old Apr 24, 2003 | 01:32 PM
tonylude94's Avatar
Default Re: H23 help (lewd43)
stock valves don't break that easily. they are made to bend and i bent valves quit a few time once on the freeway @ 4500 RPMS and they only bent. Since you were already slowing down in neutral they are probably just bent, but you know you will never know until you become the mad scientist and take her head off.
Stay True and Keep It Real
Old Apr 24, 2003 | 05:55 PM
advan-tage's Avatar
Default Re: H23 help (tonylude94)
i bent 2 of my valves...and had to rebuild the head...paid about $1600cad...i say you get a longblock h22a and build from there or just a bare block and head...and get it sleeved and ported and polished...get forged internals...go crazy...it shouldn't cost you that much if you buy the bare block and head and work from there....it will cost you time though!
i wish i would have done that to begin with...now i'm stuck with a h23 for a while...i'm gonna build from scratch!
Bender C/F
Mar 16, 2010 10:36 AM
mrfett3463
Classic Hondas
May 30, 2009 08:19 AM
ml1
Mar 28, 2007 02:32 PM
V7echnic
Mar 14, 2004 10:05 AM
