timing belt
Old 02-25-2004, 11:09 AM
nver2's Avatar
Default timing belt
On my 1988 Lude S My mechanic goes by a book on how long things should take. He said the book showed 6 hrs to change the water pump. Also 4 hrs to change the timing belt. So Im thinking this cant be right. He just dont want me bothering him to hurry the job up. Its all good cause hes still only charging me 150-175$ to do this. But I know there is no way it should take 10 hrs to do this.
Old 02-25-2004, 11:12 AM
98 blacksh's Avatar
Default Re: timing belt (nver2)
the h22 is very invovled, honda city started on mine at about 930 in the morn, had 40 min delay for a part, i didnt get it back til noon the next day
Old 02-25-2004, 11:23 AM
nver2's Avatar
Default Re: timing belt (98 blacksh)
Yeah mines not an h22 I dont know I think mine has the B20A3. I wish it had an h22.
Old 02-25-2004, 12:14 PM
Sephro's Avatar
that's book rate estimates. A good mechanic should be able to do the whole thing in a couple of hours. I am not 100% on your motor but the H's the water pump is only about 15 mins more work than the belt. Just to change the pump you need to take the TB off to get at it.
Old 02-25-2004, 12:20 PM
nver2's Avatar
Default Re: timing belt (Sephro)
well in that case is 150-175 a decent price? Also the engine I have Im almost sure of is the b20a3 and it has a carb. So it may be aggravating. The mechanic said its half carb and half FI weird.
Old 02-25-2004, 12:42 PM
Sephro's Avatar
they are charging you $150-$175??!??? Does that include the parts? I have never heard of anyone that cheap before. When I called places for mine they wanted about $600+ so I did it myself.
Old 02-25-2004, 12:58 PM
nver2's Avatar
no I bought the kit for 100$ from prostreetonline.com So with parts and labor about 250-275$ I got it changed at honda once on my Cord for over 500$
Old 02-25-2004, 03:08 PM
DW
DW's Avatar
you have the b20a3 its a dual sidedraft carb. not half this half that. that is a very good price for the tb and water pump. the reason it says the water pump will be 6 hours is because you have to spend "4 hours" to take off the tb to get the water pump off. so 4 hours to remove the tb + 2 hours to do the water pump. with a good mechanic it will take 4 hours for it all.
David
jojo ethan
10-16-2010 08:21 AM
Nocturnal
09-06-2005 10:35 PM
Digga4
06-12-2005 07:21 AM
crxh22project
01-20-2005 03:25 PM
esca
12-25-2004 04:51 PM
Quick Reply: timing belt
