throttle sticking
Old Oct 4, 2007 | 09:06 AM
theresyourproblem's Avatar
Default throttle sticking
My idle isn't bouncing(or hunting) and I just cleaned out my IACV just to make sure, but when I let off to come to a stop sign my throttle will stick at 1000-1200 rpms. After a moment it will either go down or I can pull the pedal up with my foot to bring it back to the normal 750. I have checked the cable where it connects to throttle body and it's tight, but not tight enough to keep the butterfly from completely closing. Has anyone ever had a throttle cable stick somewhere else(like in the firewall) or can I adjust the pedal spring?
Old Oct 4, 2007 | 09:28 AM
Hawkze_2.3's Avatar
Default Re: throttle sticking (theresyourproblem)
The cabl has a covering all around it except at the ends by the pedal and the throttle, so I wouldn't think it was possible for it to stick anywhere within the cable. Maybe loosen the cable at the TB a little more ans see if that helps...
You could also clean the inside of the TB and the throttle plate itself because I bet it's pretty dirty.
boostedteg1203
Jan 14, 2010 01:17 AM
NAallthewayEM1
12
Aug 1, 2009 08:41 PM
fast+forward
Sep 27, 2006 04:44 PM
blunty
Apr 22, 2002 07:51 AM
clean
Jan 21, 2002 06:01 PM
