thermostat replacement
Old Jul 9, 2005 | 12:43 PM
blulude92's Avatar
Default thermostat replacement
alright i kno this is a simple one but i've never done it b4. how much fluid am i looking at to replace? are there any little tricks i should kno about? i do have a helms manual. it's a jdm h22a. thanx guys
Old Jul 9, 2005 | 12:45 PM
blulude92's Avatar
Default Re: thermostat replacement (blulude92)
oh and should i try to catch any of the fluid and how would u recommend doin that?
Old Jul 9, 2005 | 07:45 PM
brolli's Avatar
you will probably only loose maybe half a gallon at the most. dont catch the fluid you loose becuase it wouldbe hard plus woujld get dirt in it most likely. whenever i replace a thermostat i always flush the system anyways becuase if you dont flush it every say 50k miles the dissimilar metals the coolant comes in contact with will make the fluid become acidic, rotting your heater core and making your car smell like antifreeze on a cold winter morning. so if its been more that 50k since it was last flushed i would spend the extra 20 bucks which could save you a lot more time and money in the long run. to flush run plain water probably from a hose thru the line at the radiator until the coolant is all gone. then take compressed air and blow the water out being careful not to exceed like 20 psi inside the radiator and such.
Old Jul 9, 2005 | 09:25 PM
PrettyLude's Avatar
remember to put back that ground on the thermostat housing
Old Jul 11, 2005 | 06:00 AM
blulude92's Avatar
Default Re: (PrettyLude)
hmm looks like there was no ground on the thermo housing to start with. is this bad? and if i put one on there where should i ground it to?
chichaster
Honda Civic (2001 - 2005)
Aug 22, 2008 04:37 PM
CRISIS
Jan 6, 2007 10:45 AM
mrx
Jun 18, 2006 10:21 AM
migs
Dec 20, 2002 06:14 PM
TurBoXBirD16
Jun 5, 2002 04:54 AM
