is there a stock map sensor
Old Jan 21, 2009 | 12:59 PM
92prelude23's Avatar
Default is there a stock map sensor
i was wondering if there is a stock map sensor on my 92 prelude h23 and where it is?
thank you.
Old Jan 21, 2009 | 02:21 PM
dixxon's Avatar
Default Re: is there a stock map sensor
IIRC it's attached to the firewall by a bracket behind the intake manifold. It's connected to the intake manifold by a series of vacuum lines.
Old Jan 21, 2009 | 02:25 PM
Hawkze_2.3's Avatar
Yes, should be on the firewall right behind the throttle body. If not, it will be bolted onto the top of the throttle body.
Old Jan 23, 2009 | 07:20 PM
Default new throttle body and tps smoking.
Yea i thought that was it but i was not sure. also i got a 70mm throttle body and a new tps with it to. in the direction for the tps it says to use a volt meter and connect the black wire to chassis ground and the red wire to the center wire on the tps sensor plug. and when the engine is off check voltage on the center wire of the tps connector. adjust the rotation of the tps sensor till .45 volts is achieved then tighten the bolts that secure the tps to the throttle body. i didnt really think it was a big deal to do this so i put it all on and started the car up and the car almost died and smoke was coming out of the area of the throttle body/mani. could the smoking be a reason for me not using a volt meter on the new tps?
Old Jan 25, 2009 | 11:24 AM
anyone?
Old Jan 25, 2009 | 02:42 PM
rjr162's Avatar
Yeah, the TPS tells the ECU the position of the throttle plate. WOT on a Prelude should be around 5V according to the Hemls manual (can't remember exact amount). If I remember right, I believe mine measured 4.6
Old Jan 25, 2009 | 06:02 PM
well how can i go about on fixing this and where would i get the tool.
thank you
Old Jan 26, 2009 | 09:23 AM
Hawkze_2.3's Avatar
You can buy a multimeter most anywhere, Home Depot, Wal-mart, auto parts store, etc... I would not advise you get a cheapo one ($5-15), get a decent one with digital readout and you will be much happier.
Why are using a bog throttle body, sounds like you just need to keep the stock throttle body on there and leave it alone.
Old Jan 26, 2009 | 01:29 PM
okay cool. well my tps went up on it and my lude is turboed and i have been wanting to upgrade my throttle body and get more power anyways so i just did it now.
sirtef9
Jun 17, 2014 05:15 PM
jake1191
Engine Management and Tuning
Jul 18, 2011 06:42 AM
chrisff521
Apr 5, 2009 07:26 PM
92prelude23
Jan 26, 2009 05:43 PM
jisecup
Jul 4, 2003 06:18 PM
