Easy question...hit a cement pole yesturday now I am having problems driving
Hey guys, yesterday after class I was reversing in the underground parking lot and smacked my front passenger fender against a cement pole.
Now I am replacing my fender this weekend but when I drive straight my steering wheel seems off a bit.
What can I do to correct this??? the frame isn't bent but it has a small dent but not something that would affect the suspension steering.
Thanks
Modified by Mr.RHTuner at 4:57 PM 11/10/2004
Thanks
Re: Easy question...hit a cement pole yesturday now I am having problems driving (Mr.RHTuner)
Probally just bumped your alignment out of whack. Go get an alignment done and you'll be fine.
EDIT: They'll also let you know if anything could be bent, because they won't be able to get the alignment right.
Re: Easy question...hit a cement pole yesturday now I am having problems driving (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Alignment. </TD></TR></TABLE>
Agreed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner »</TD></TR><TR><TD CLASS="quote"> Easy question...hit a cement pole yesturday now I am having problems driving</TD></TR></TABLE>
If you hit a cement pole, sounds like you were having trouble driving before ;-)
j/k
Take it to sears... if you get an alignment there, and come back every 5 months, you can have free alignments for life!
Agreed
j/k
Re: Easy question...hit a cement pole yesturday now I am having problems driving (JDMallTHEway)
Thanks guys...I knew its going to be an Alignment but I wanted to be sure so before I went out and blew money on something that wouldn't correct it.
What happened was I got kicked out of my parking spot when I go to school so I parked in an underground parking lot beside a cement pole. When I got back from class I was thinking about if I'm going to go to my next period and I got into my car, turned on the car and started to turn the wheel and reverse.
Next thing I know is I hear BAM and I stop, get out and see my fender mangled.
I had my head up my *** because of school...that will never happen again
You live and learn. If Sears has a lifetime alignment deal going on, I strongly recommend it. 3 alignments in you've paid for it and then some and you can get it done as often as you like.
Re: Easy question...hit a cement pole yesturday now I am having problems driving (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">You live and learn. If Sears has a lifetime alignment deal going on, I strongly recommend it. 3 alignments in you've paid for it and then some and you can get it done as often as you like. </TD></TR></TABLE>
I'm located in Ontario Canada so I never heard about this. Never knew sears does automotive at all, but thanks for the info man I'll look into it today
