Stroker Kit?
Old Feb 8, 2002 | 02:39 PM
Toretto's Avatar
Default Stroker Kit?
Does crower, or any other respectable companie for that matter make a stroker kit for the H22?
Old Feb 8, 2002 | 03:02 PM
bb6h22a's Avatar
Default How about..
..using the search engine? It's utterly possible that in our world and the probabilities of chance that govern it. Some one, some where, at some time must have had the same profound and astute dillema that presents you today, and lo and behold, eureka!:
https://honda-tech.com/zerothread?id=84835
Old Feb 8, 2002 | 04:00 PM
H22pwrd's Avatar
Default Re: Stroker Kit? (Toretto)
Contact Darrin from R&D Dyno of Gardena, CA. Who is he, you wonder. He's just the guy who built L'Natural's motor, you know the quickest all-motor Honda on the planet. He has a 2.5 stroker kit that is doable on 91 octane. I think he mentioned 220+ at the wheels for the setup.
Old Feb 8, 2002 | 04:14 PM
Toretto's Avatar
Default Re: Stroker Kit? (H22pwrd)
Sorry, forgot about the search feature. But thanks for the link.
Old Feb 8, 2002 | 05:05 PM
Toretto's Avatar
220 to the wheels and he is the fastest honda on the planet? Whats the H22 in? Cause it sure cant be in a prelude. Does the .3L of displacement really make that big of a differance? I would assume he is running high compression pistons also, probably 13:1. How is it that All motor Ludes, like JGLuders all motor beast can run low 13's with only 260whp, but it seems like it takes more HP for the boost and juice guys to get the same times.
Old Feb 8, 2002 | 07:44 PM
H22pwrd's Avatar
You're kidding right. 220 wheel horsepower ain't gonna cut it nowadays, even in a CRX. That stroker kit is a streetable version - again doable on 91 octane. If you have the moola to run racing fuel everyday, then the sky's the limit as far as compression limits are concerned. Oh, that .3 difference in compression equals turbo upgrade to some, as in F-1.
You might wanna contact Jeff from Import Builders from Santa Ana, CA too. His ITB setup, that he claims does 20 mpg sounds, real nice.
Old Feb 8, 2002 | 08:13 PM
Toretto's Avatar
You stated he is the fastest all motor Honda in the world, so I am a bit confused. The crower stroker kit looks awsome, billet rods, billet crank, and forged pistons all balanced for drop in installation equals a bullet proof engine. Then use the cams of your choice, boost or juice for some good FI, and alot of tuning time to get it to perfection. Hell, if I get 210whp out of my motor after the rebuild, I would be pretty happy, and let the juice do the job for racing. I wonder I much juice I could run safely on a completely rebuilt H22?
[Modified by Toretto, 5:16 AM 2/9/2002]
Old Feb 8, 2002 | 08:46 PM
Diversion's Avatar
Yes, Crower makes a stroker kit that will bump up your CC to 2500ish... A lot of people have said 2.5 liter is the most you want to bore to for street use.. going past 2.5 liters makes the cylinder walls too thin, and you're liable to blow your motor. And yes, having a 2.5L H22A makes a TON of power. Refer to the old post that has the 2.6L H22A dyno in it, I think it was 228 hp to the wheels. And about 175 ft lbs of torque if I remember correctly.
That would be an insane N/A car.
Jay
[Modified by Diversion, 12:48 AM 2/9/2002]
Old Feb 8, 2002 | 08:59 PM
kenshi23's Avatar
Default Re: Stroker Kit? (Diversion)
what is the stock WHP for the h22?
Old Feb 8, 2002 | 09:04 PM
Diversion's Avatar
Default Re: Stroker Kit? (kenshi23)
158 to 161 is the typical stock WHP.
That sort of loss is too great for a car at 200hp stock, so i've always believed that 5th gen Preludes are really rated at 190 to 195 horsepower.. not 200.
Jay
Old Feb 8, 2002 | 10:34 PM
laughinxxx's Avatar
New User
Stroker kits are nice, but you can say good-bye to a high redline. Personally, I'd bore the cylinders out to give you 2.3 liters after you resleeved and rebuilt the bottom end.
Old Feb 9, 2002 | 07:09 AM
John's Avatar
New User
Default Re: Stroker Kit? (laughin2.2)
yeah, 2Point6 has a 4G Accord with a H22 stroked to 2.57L... IM him, i'm sure he'd supply you with additional details...
Old Feb 9, 2002 | 07:13 AM
Toretto's Avatar
With the stroker kit, you dont bore out the cylinders, or do you? The way I understand it, from the crower website, it just makes for a londer stroke, so the pistons move up and down further than they used to. And along with the stroker kit, you could bore the cylinders out, and get even more displacement, but might not be worth it , just incase you need to have it bored out down the road cause of an engine failure. Laughin2.2, when you say no high RPM, do you mean less than we have stock? With a completely rebuild engine using the stroker kit, and some new cams, I would bet than you could stilll rev freely to 7500+, yea, that no 9300 rpms, but its not bad, and since I will be running nitrous, I wont really need a high reving engine. Anyone know how much nitrous I would be able to run?
Old Feb 9, 2002 | 08:29 AM
boomslang's Avatar
260 wheel horse power! Hahahhahaha. I respect JG's car but there is no way it was putting out 260 whp.
Old Feb 9, 2002 | 09:07 AM
Toretto's Avatar
Default Re: Stroker Kit? (Inlinefour)
It was somthin like that before it blew up. I know it was high for all motor.
OK, I was just doing a search, and have noticed alot of negative things about stoker kits, such as reliablity issues, and its not really worth it when the risk is considered. So I am pretty much cancelling out that idea. Laughin2.2, you are going to be running nitrous, and so am I, do you know if we can run nos and have a high reving engine? I know after a rebuild, the revablity goes up, and alot of that has to do with the cams, but could I run nitrous and still have a high reving engine? I was thinking maybe use the nitrous from about 3k to 7k rpms, and then let the VTEC power get me to about 9k rpm. Since I will want a forged crank for the massive amount of nitrous at the tracks.
[Modified by Toretto, 6:40 PM 2/9/2002]
Old Feb 9, 2002 | 09:41 AM
laughinxxx's Avatar
New User
1. With the stroker kit, you dont bore out the cylinders, or do you?
2. Laughin2.2, when you say no high RPM, do you mean less than we have stock? 3. Anyone know how much nitrous I would be able to run?
1. You don't have to bore the cylinders out.
2. I'm honestly not sure, but the complaint that I here with stroker kits is that you lose revability. Can anyone back me up on this or prove me wrong?
3. As much as you want after you take the piston cr and fuel octane into consideration.
Old Feb 9, 2002 | 10:23 AM
JG Luder's Avatar
Well, I never hit 260whp... I was probably in the 220's untuned, and 230-240 tuned (which I never had a chance to get. :mad But we'll never know for sure I guess. JG Built my motor for 220 whp w/o cams (cause they don't make them)
And w/o a few other goodies I had. I think that 20whp with tuning on this set of cams and VAFC etc. was feasable. However, I try not to speak with definate certainty, cause like I said, we'll never know for sure.
L'Natural is running 270 whp I believe. However, when the old school skunk teg was running mid 11's, he was only putting down 220.
Anyway, I have heard bad things about the stroker kit. I talked to JUN back in the day (over two years ago), and they said they made a kit, but never had any luck with it, so they scrapped that idea. Now, if JUN scraps an idea, it's pretty bad. I don't know what their thoughts are on it now...
Oh, and you can bore to roughly 2.5L. It's 90mm and not the most streetable bore. I know someone with it, and I saw his motor before reassembly. (Full out race car) The sleeves have to be notched to fit next to eachother! I went with an 89mm bore, and it yields about 2.35L as opposed to the stock 2.15. So about .2L more. You still have a little room to screw up and bore again if you, oh... drop a valve and scar a cylinder wall... (sound familiar?)
Anyway, thats just make take on things.
Old Feb 9, 2002 | 11:21 AM
boomslang's Avatar
Depends. Are you going to have a deckplate added to the block along with the stroker crank and custom longer rods? Then no, you won't lose revability. The rod to stroke ratio could still remain good.
If you just put a stroker crank the stock block along with custom shorter rods, then the motor won't be as rev happy because of the poor rod to stroke ratio.
Old Feb 11, 2002 | 03:27 AM
vntperformance's Avatar
Exactly...i couldn't agree with inlinefour anymore!
vnt
Old Feb 11, 2002 | 05:44 PM
apexii's Avatar
Default Re: Stroker Kit? (JG Luder)
Well said JG
90mm is crazy, although not as crazy as 260 n/a whp. I know someone who went there with his h22. Blew headgaskets non-stop.
Old Feb 12, 2002 | 11:56 AM
2point6's Avatar
Default Re: Stroker Kit? (apexii)
no problems with the stroker yet.
Old Feb 12, 2002 | 12:25 PM
apexii's Avatar
Default Re: Stroker Kit? (2point6)
Nice, one heck of a motor to build on. In my above post I was talking about a stock crank/stroke, just a 90+mm bore. The sleeves were so thin they leaked in the corners...
borislunov
Aug 20, 2009 02:35 PM
@kprelude
Oct 18, 2006 04:22 PM
mozzandherb
Jun 30, 2006 08:32 AM
3a_eg_hatch
Apr 6, 2006 05:13 PM
