stripped philips head.
Old Oct 14, 2005 | 03:18 PM
SNsLude's Avatar
Default stripped philips head.
The two philips screws that hold the heat sink on in the dizzy above the ignitor unit were jammed tight. I tried twice, second time with the more proper sized bit and that was enough to strip it. The heads are extremeley soft and they are screwed on pretty tight; probably from lack of taking out so it prob has a lot of gunk stuck in there.
Anyway, I tried hammering a deeper longer slot to try a flat head and it just doesn't get enough grip- strips it further.
Any ideas? I don't really want to drill because I don't know how long/short those screws are and, secondly, afraid might damage the dizzy housing.
Anything else I can probably do?
Old Oct 14, 2005 | 03:24 PM
The_Sober's Avatar
Default Re: stripped philips head. (SNsLude)
dremel a new, deeper cross-hatch into the top and try again.
Old Oct 14, 2005 | 03:35 PM
SNsLude's Avatar
Default Re: stripped philips head. (Sober_John)
Bleh, no dremel handy. Is that pretty much my last option aside from drilling? No kits or anything from stores to remedy this? If not then I guess I'll need to buy one..
Old Oct 14, 2005 | 04:38 PM
LudeyKrus's Avatar
EZ Outs, the reverse drill bits. Also, try the Dremel trick. It works great when you can get a cutting disk down into where the screw is.
Phillips head screws are a cruel joke....
W.O.P.
Apr 28, 2004 03:34 PM
FcUK It.
17
Oct 9, 2003 03:18 PM
ih8danoles
Apr 21, 2003 12:21 PM
type autox
Jan 21, 2002 06:55 PM
typerlover
Dec 28, 2001 02:07 PM
