Steering arm problem
Old Aug 20, 2005 | 02:45 PM
CCRX's Avatar
Default Steering arm problem
I have heard a thumping/ clicking/ not right noise from the left front of my 97 SH. I investigated and it seems the arm has play in the box/rack/ gear. the hub will move towards and away from the gear (rack whatever you techie ppl call it) but the steering wheel doesnt move. The hub will however not move up and down. so that rules out ball joints.
OKay so my question is this. What parts could it be that are bad? Would it be the steering arm itself, the thing that connects it to the gearbox or the $800 gear box itself?
Old Aug 23, 2005 | 05:07 AM
CCRX's Avatar
Default Re: Steering arm problem (CCRX)
bump
no one want to guess at this one?
Old Aug 23, 2005 | 05:15 AM
mgags7's Avatar
did you check and make sure its not the axle first, does it only do it when you are turning?
i have never heard of a rack going bad in a prelude, so im thinkin thats kinda unlikely, maybe just a new tie rod end....
Old Aug 28, 2005 | 03:31 PM
kapuchnik's Avatar
I have the exact same prob on my '97 civic. I've been searching for a steering assembly diagram but have had no luck so far. Most likely the problem is a worn location bush but I'd like to be certain. Do you also feel some slight vibrations/heavy steering or slightly more vigorous vibration during braking? All this occurs due to loss of steering tracking because of the loose play in the steering system. If anyone knows anything or has any Honda steering assembly diagrams please let me know, I'd highly appreciate it!! )
Assassinxiv
Suspension & Brakes
May 13, 2013 02:45 PM
Drop_A_Dookie
12
Feb 13, 2011 07:56 PM
Annihilator
Feb 9, 2011 12:03 AM
gunterelectric226
25
Mar 10, 2009 08:17 PM
S.Celia
Dec 8, 2003 04:46 PM
