speaker installation
Old Sep 8, 2002 | 10:54 AM
n0 iNTegRiTY's Avatar
Default speaker installation
I am asking help for anyone who has installed their own speakers in their car. Im trying to install some new front and rear speakers in my 94 integra GSR. Im having trouble getting to the door to drill in some holes to screw the speakers in and im wondering if i have to take off the entire door panel, and if so, how hard it is to put it back on. I see one screw towards the top of the door and to the front of it and i know theres more holding the panel on, but im not sure if its glued on or what. PLEASE HELP
Old Sep 8, 2002 | 11:42 AM
o_Rage_o's Avatar
Default Re: speaker installation (RAF LTD. 2)
https://honda-tech.com/zerothread?id=263634
remove the screws in the door change pocket. remove the screw behind the flap on the door handle, pull out the plastic up and over the handle, remove the wire from behind it. pry off the door panel with your hands starting from the outside lower edge, and work your way around the bottom, now you have the bottom out, pull it out at a small angle, pry off the top of the door panel. You may have to remove the power mirror plastic peice in order to get the panel off.
Follow the guy's advice in the link i gave you, and don't be afraid to use a little force.
Good Luck
-Rage
Old Sep 13, 2002 | 05:09 AM
Default Re: speaker installation (o_Rage_o)
yea, thanks for the help man.
cennouu
Dec 23, 2010 04:12 PM
Hyard24
Audio / Security / Video
Jan 16, 2008 08:12 AM
Si Arn
Jan 9, 2004 08:00 PM
onyx00
Sep 5, 2001 12:44 PM
sicilian2k1
Aug 21, 2001 03:52 AM
