Smallest Wheel you can fit on a Lude ?
Just wondering what is the smallest wheel i could fit on my Prelude, because I plan on getting some small wheels to fit some slicks on...
Guest
Posts: n/a
Re: Smallest Wheel you can fit on a Lude ? (C-Redrum)
you've got a 5th gen right....... you might be able to get some 15s on there, if your lucky, when the 16s are on, it is a close fit to the caliper, some Panosport 15s or something made similarly should fit
Re: Smallest Wheel you can fit on a Lude ? (EX-Boosted97Lude)
5th gen..correct.
Damn, Then i wonder what size slick i can fit..id probably have to raise her up alot..
Most 15" rims will fit. You MIGHT be able to get a set of 14" to fit but they'd have to have to give as MUCH room as possible... Probably not lower end production rims that fit that 14" bill though.
well you can fit a 15" wheel on. i had 22x8x15 slicks and had no problems at all with clearance, i have some 24.5x8.5x15's on the way well that should be here 2mrw so as soon as i get them mounted and tested ill let you know..
Re: Smallest Wheel you can fit on a Lude ? (TurboLude97)
sweet. Yeah let me know how those slicks work out. What kind of wheels are you running and what size ?
infamousALLMTR
02-17-2002 04:32 PM
