Shift Linkage problem
Old Mar 10, 2007 | 03:23 PM
AndrePerras's Avatar
Default Shift Linkage problem
CAR: 1997 PRELUDE H22 Manual LSD
Ok so i got my manual swap back from the garage and it drove fine all night, and today... as i shifted from 2nd to 3rd the shift **** went all the way to where the gear is supposed to be, but its as if there was no gear there... I then realized that all of the "top" gears were like that, 1st, 3rd, and 5th. My 2nd and 4th gears worked fine. Is it possible that one of my shift cables came un hooked ? I've read some stuff about a "bitch pin". Is this the problem ? Any input is appreciated... Here's a diagrom of my shift assembly.
I think the cotter pin fell off, and the select link pin came out... Is this possible ?
Any input appreciated.. thanks !
Old Mar 10, 2007 | 03:30 PM
prelude1897's Avatar
Default Re: Shift Linkage problem (AndrePerras)
open your hood and look at the cable to be sure they're still hooked up
Old Mar 10, 2007 | 03:33 PM
Default Re: Shift Linkage problem (prelude1897)
ok, it's freezing cold right now and dark, so i'll probably do it later once i get a few more suggestions so i dont have to go outside again...
any other suggestions ? Much appreciated.
Old Mar 10, 2007 | 04:01 PM
jdmlude5
Guest
Posts: n/a
yeah look at the cables make sure they r still ok under the hood. and at the shifter..
Old Mar 10, 2007 | 05:43 PM
Default Re: Shift Linkage problem (jdmlude5)
Ok problem solved, the bung around the shifter cable (at the shifteR) unclipped, and the shifter was pulling on the hose instead of the cable inside.
Thanks for the input !!
norcal450
Honda Civic (2006 - 2015)
16
Sep 20, 2007 10:26 AM
Boostedb20EH2
May 4, 2007 01:51 PM
petrv
Mar 28, 2006 07:10 AM
sohc prelude
Feb 26, 2006 07:26 PM
The Rob
Jun 21, 2002 11:31 AM
