SENSOR HELP!!!
Old 04-26-2015, 08:50 AM
NeverSummer32's Avatar
Default SENSOR HELP!!!
So i have a 95 prelude bb1 h22a1. And it was running fine but then started bogging but no cels. I was looking under the hood at the tps but then followed the wire and one wire is disconnected from what looks to be a sensor on the area around where the lower radiator hose connects to... Could this be the cause of my bad idle? and there is no pigtail connector on one end. But the Female end near the lower radiator hose hook-up is yellow.... what is this?!?! please help
Old 04-26-2015, 10:40 AM
sytntyt's Avatar
Default Re: SENSOR HELP!!!
sensor in the bottom of radiator? most likely a coolant temp sensor.
Old 04-26-2015, 03:03 PM
holmesnmanny's Avatar
take a detailed pic for us to see
Old 04-26-2015, 04:24 PM
Thats the lower radiator hose
Old 04-26-2015, 04:31 PM
Global Moderator
tech8's Avatar
That is engine coolant temperature Switch A. It is a fan switch to trigger both cooling fans if the coolant temperature is above 199 degrees F or above (for Si, S, 4WS) or 203 degrees F or above (for VTEC or SR-V) with the engine running.
Billy Baird
12-27-2012 10:32 AM
4CDFED
11
08-09-2006 06:03 PM
Rival23
10-22-2003 08:48 AM
Saltine Box Racer
06-06-2002 01:11 PM
BluLuder
12-12-2001 09:47 AM
Quick Reply: SENSOR HELP!!!
