S2000 killer
Old Mar 3, 2002 | 09:33 AM
95dirtylude's Avatar
Default S2000 killer
I have MSD ignition, and skunk2 cams, springs, and retainers. All of these parts have a redline of at least 11,000 rpm. The primary reason cars have a redline is because they start to experience vavlve float and detonation afterwards. With these new parts can i safely up my redline to 9500 or so?
Old Mar 3, 2002 | 09:52 AM
laughinxxx's Avatar
New User
Default Re: S2000 killer (95dirtylude)
You forgot about the rods. When you rev an engine that high the rods start to bend and if they bend enough they can break or allow the pistons to go off course enough, so that they hit the cylinder walls.
Old Mar 3, 2002 | 10:02 AM
SMSP's Avatar
Why do you want to rev the engine to the point where it is making less power and causing undue stress to it's components?
Old Mar 3, 2002 | 10:38 AM
boomslang's Avatar
Default Re: S2000 killer (SMSP)
You won't make any power up that high, it's pointless.
Old Mar 3, 2002 | 12:08 PM
migo's Avatar
New User
Default Re: S2000 killer (Inlinefour)
He's right. The higher the lift the higher revs = More horsepower. Depends on the set-up you use. Definetly get the rods
Old Mar 3, 2002 | 12:53 PM
aklucsarits's Avatar
New User
The geometry of the H22a simply does not lend itself to high rpms. It is already an undersquare stroked motor from the factory. Due to its long stroke, the piston speeds and the resulting acceleration and deceleration of the pistons at high rpms are unsustainable. With the pistons accelerating and decelerating so rapidly, the rod ends tend to "egg". Even with upgraded rods, I would think that around 8600rpm would be about the limit for a semi-reliable bottom end...
And also, as others have pointed out - even your Crower cams are not going to make any power over that point anyway...
If you just want high rpms for the sake of having high rpms, then look into de-stroking the H22a motor to 2.0l with the crank from the f20b DOHC VTEC Accord SiR-T
Andrew
Old Mar 3, 2002 | 04:45 PM
H22Si's Avatar
Default Re: S2000 killer (aklucsarits)
I completely agree. I you are interested in turning higher RPMs for for power, destroke it. At least for reliabilities sake.
Old Mar 3, 2002 | 08:46 PM
Asian Persuasion's Avatar
Default Re: S2000 killer (H22Si)
Speaking of the Skunk2 cams, does anybody know what RPM the peak power is at on those? I was thinking of getting the stage2 cams and wanted to know a little bit more about them before getting them. If anybody also has any dynosheets... please post here.
Thanks
Old Mar 3, 2002 | 11:15 PM
Deadly-Lude's Avatar
The max I am going is gonna be around 9200 rpms with pistons, rods, valves, cams, springs, retainers, and a very well balanced motor. So I dont advise you to rev anymore than 8500 with your current mods.
Old Mar 4, 2002 | 07:37 AM
BoM's Avatar
BoM
Default Re: S2000 killer (Deadly-Lude)
destroke the motor if you want to rev that high.
stroke the motor and just rev to 8k
its hard to have the best of both worlds of torque and horsepower
DarkRattle
Aug 10, 2017 05:18 PM
mrod006
Aug 5, 2004 07:31 AM
civcexcoupeblack
Apr 1, 2003 06:24 PM
comptechgsr
Apr 24, 2002 06:03 PM
Toretto
Jan 23, 2002 06:30 PM
