Rewiring for External Coil Dizzy
Old Jun 6, 2005 | 01:49 PM
monalisa overdrive's Avatar
Default Rewiring for External Coil Dizzy
Hey guys, quick question:
Does anyone know how to wire the dizzy off of a USDM H23A1 (External Coil) for use on a JDM H22A (Internal Coil)?
My ignitor just went, and I still have my old H23A1 from before the swap with the dizzy. I'd like to use that if possible.
Also, another important question:
Are the Cap+Rotor interchangeable between these two distributors? The cap and possibly rotor on my H23A1 is broken but the one on the H22A is still good.
Thanks for the help.
Old Jun 6, 2005 | 02:49 PM
Greyout's Avatar
Default Re: Rewiring for External Coil Dizzy (monalisa overdrive)
the cap is definately not interchangable.
Old Jun 7, 2005 | 09:52 AM
Default Re: Rewiring for External Coil Dizzy (Greyout)
i guess i gotta get a new cap then... anybody know how to make my JDM H22A work with the external coil dizzy from my old H23A1?
Old Jun 7, 2005 | 11:00 AM
h8trix's Avatar
ummm, do you want to keep internal coil? If you don't care just take your h23 distributor and put it on the h22... its not a big deal. You can move the externel coil over too, you should be able to find a place to mount it with a bracket, if not just zip tie it somewhere (some guy on PO ziptied it to his AC lines)
2point6
Mar 14, 2017 08:54 AM
2mchbst
May 22, 2009 08:53 PM
pkolaboy
Jun 2, 2008 09:17 PM
2point6
May 25, 2006 05:21 AM
servion
Jun 20, 2002 08:59 AM
