Reving/accelerating problems?
Old Dec 8, 2004 | 11:27 AM
aboh6leenz's Avatar
Default Reving/accelerating problems?
Today when i was driving home i noticed something wrong. I was in 2nd gear and trtied to accelerate and my needle reved up to 4k rpm pretty quick, then it drops about 500 rpm. I tried it again and it did it again, even in 3rd gear it did it also.
I'm thinking my clutch is slipping, but can anyone confirm this? And if so what clutch/flywheel should i get next?
Thanks
Old Dec 8, 2004 | 12:05 PM
Sephro's Avatar
Default Re: Reving/accelerating problems? (aboh6leenz)
You mean that the revs go up but the car does not go?
Yes that is your clutch.
Old Dec 8, 2004 | 02:15 PM
aboh6leenz's Avatar
Default Re: Reving/accelerating problems? (Sephro)
well yeah basically. My car does go though just not what is should be going for the rpms going up so fast.
Whats a good clutch for daily driving?
Old Dec 8, 2004 | 02:24 PM
Elkins911's Avatar
Oem will be your best bet for daily driving
Old Dec 8, 2004 | 02:42 PM
aboh6leenz's Avatar
Default Re: Reving/accelerating problems? (Elkins911)
hook it up with a site or something so i can purchase one
anyone elses input would be greatly appreciated.
Old Dec 8, 2004 | 03:06 PM
mgags7's Avatar
you could get a clutchmasters oem replacement clutch, or go with a stage I
i have the stage one and its basically stock feel....maybe a little harder but nothing bad for daily driving......
search on google for the clutchmasters site...i cant remember it
Old Dec 8, 2004 | 03:44 PM
aboh6leenz's Avatar
Default Re: (mgags7)
should i just get an oem clutch and resurface the flywheel?
Old Dec 9, 2004 | 06:48 PM
Gerhard_001's Avatar
Default Re: (aboh6leenz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aboh6leenz &raquo;</TD></TR><TR><TD CLASS="quote">should i just get an oem clutch and resurface the flywheel?</TD></TR></TABLE>
OEM is Your best bet. No need for an upgraded clutch kit unless you can get it for less than the cost of an OEM clutch kit.
Old Dec 9, 2004 | 06:50 PM
Shakes's Avatar
space cadet
Default Re: (Gerhard_001)
ACT XTSS and a 12 lb flywheel on my daily driver. your ankle will get used to it after a couple weeks. then everything else feels non existant
Old Dec 9, 2004 | 06:55 PM
prylwd's Avatar
If you want to upgrade the act streetlite flywheel will be ok for daliy driving. The OEM will be cheaper and work fine though if you are just looking to get back on the road.
carbone
Transmission & Drivetrain
Oct 8, 2015 09:18 PM
R81_DC2
Nov 14, 2008 07:59 PM
LukieLuc
Jun 24, 2007 10:37 AM
litterbox
11
Sep 2, 2005 04:40 AM
Seann
Jan 31, 2003 02:48 AM
