removing secondaries
Old May 16, 2002 | 11:57 AM
servion's Avatar
Default removing secondaries
I just pickup up an H22, and my mechanic told me that I should remove the plate in my intake manifold for better performance.... anyone heard of this? any thoughts?
Old May 16, 2002 | 12:01 PM
Prelude Vtec 23's Avatar
Default Re: removing secondaries (servion)
Yeah you can do that, your talking about the 2nd butterfly on your intake manifold right? You'll lose some low end but gain high end since your shortening the runners.
Old May 28, 2002 | 11:43 AM
servion's Avatar
Default Re: removing secondaries (Prelude Vtec 23)
will the gains in the high end make up for the loss in the low end (i.e., 1/4 time better or worse)?
Old May 28, 2002 | 12:01 PM
apexii's Avatar
This mod is not worth it. I have debated it to no end, and i've come to the conclusion that you will lose more than gain. For a mild setup it's not going to be worth it. Just my opinion.
Old May 28, 2002 | 05:07 PM
kevie88's Avatar
Default Re: removing secondaries (apexii)
I thought a lot about this as well, and I was thinking that our cars need all the help they can get in the low-end, and I decided not to remove them (or disable them). I'd like to do a dyno run side by side (easy enough to do) with them stock and with the butterflys disabled to see if it helps anything. I have a feeling I'm just screwing up Honda's great engineering!
Old Jun 11, 2002 | 11:55 AM
servion's Avatar
Default Re: removing secondaries (kevie88)
anyone done this side-by-side comparison?
Old Jun 12, 2002 | 08:51 PM
DYI01's Avatar
i dont see how removing them will gain anywhere. In low rpm it restricts the induction so it has better low end performance. Past 5000 rpm the runners open making like if the butterflies were removed. You WILL NOT GAIN anything from doing this.
Old Jun 12, 2002 | 10:13 PM
Greyout's Avatar
Default Re: removing secondaries (DYI01)
if you want to go all the way, then take out the center section (not just unplug it) then tak e a grinder and turn the 8 holes into 1 big opening that splits into 4 runners down inside it
[Modified by JDM LUDE, 7:13 AM 6/13/2002]
Old Jun 12, 2002 | 11:14 PM
dustin's Avatar
Agree.
Old Jun 12, 2002 | 11:27 PM
thejdmkid's Avatar
Default Re: removing secondaries (dustin)
i second that, just like saying that pulleys help ur car........
Old Jun 12, 2002 | 11:54 PM
aeolus's Avatar
Default Re: removing secondaries (JDM LUDE)
i have an intake manifold where i did that.It performed like ****.i woudnt recommend it.Takes alot of time to do.And it made the cars low end disapear.i re-installed a stock one WITH the butterflies...runs beautifully.And it saves gas too!!
[Modified by aeolus, 8:55 AM 6/13/2002]
Old Jun 14, 2002 | 09:57 AM
LoudLude's Avatar
Default Re: removing secondaries (aeolus)
I also urge you not to do it. If it was a race-car, maybe, but when you remove those runners you may even get a "bog" below 3k rpm, which will get quite annoying in a daily driver.
VTECcnIT
Apr 21, 2006 08:58 AM
Go n 4 10s
Feb 14, 2006 04:31 PM
dnbruut
Aug 1, 2005 07:42 AM
OzWolfbane
Mar 9, 2005 04:23 AM
DBumba
Sep 2, 2004 12:36 PM
