Radiator Clearance Issues...
Old Feb 27, 2004 | 07:19 AM
NOTENOUGHBOOST's Avatar
Default Radiator Clearance Issues...
Anyone else have problems when first putting in your turbo setup? Basicly I have a Rev-Hard setup on a 99 Prelude. The turbo is just about touching the upper radiator hose and the turbo is almost touching the fans.
Just want to know what you did to resolve... I'm going to spend all day after I get off trying to work it out.
Old Feb 27, 2004 | 07:23 AM
Revi's Avatar
Default Re: Radiator Clearance Issues... (littlechoppab20)
Almost everyone who installs a turbo will clearance issues somewhere in there. Might want to talk to PrecisionH23a, he heavily modified his radiator. Could get some tips.
Old Feb 27, 2004 | 07:34 AM
Default Re: Radiator Clearance Issues... (Revi-Ra)
Thanks dude.. aslong as I'm not the only one.... I'm probably going to shave my fan a little bit and replace my radiator hose with steel braided hose just incase turbo rubs as motor moves.
Old Feb 27, 2004 | 08:22 AM
Accel Junky's Avatar
Agreed. I had this same problem on my integra, and I simply cut a section of fan shroud off and the clearance was good after that. No fan problems resulted.
As for the hose, I definitely agree about the steel braiding or maybe even finding a silicone hose (www.bakerprecision.com)
Old Feb 27, 2004 | 09:01 AM
Default Re: (Ibuprofec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ibuprofec &raquo;</TD></TR><TR><TD CLASS="quote">Agreed. I had this same problem on my integra, and I simply cut a section of fan shroud off and the clearance was good after that. No fan problems resulted.
As for the hose, I definitely agree about the steel braiding or maybe even finding a silicone hose (www.bakerprecision.com)</TD></TR></TABLE>
Thanks for the info... I might be better off though with the steel braided if my turbo is to close/touches almost. Don't want to have to worry about wearing on hose.
littlewagon
Aug 21, 2011 10:52 PM
daddy
Honda Civic (2001 - 2005)
13
Jan 31, 2008 05:25 AM
95whitegizzer
Jun 28, 2006 09:47 AM
JO
Aug 31, 2003 05:46 PM
d mafia
Jan 19, 2002 06:26 PM
