Pulsing IDLE?!?!?
Old Dec 15, 2002 | 06:55 PM
yoshio006's Avatar
Default Pulsing IDLE?!?!?
well my Idle is pulsing only when I hold it at any certain rpm. Its fine at Idle when I leave it alone, if that makes sense. When I try to drive the car it go's 4 feet and falls on its face. It doesnt shut off it just stops moving like Im gettin cut off or somehting. Im pretty sure its not a vacume problem. could it be a TPS or MAP sensor? Need help.
Old Dec 16, 2002 | 06:37 AM
prelude1897's Avatar
Default Re: Pulsing IDLE?!?!? (yoshio006)
Is your check engine light on? If it is, see what code its throwing and you should find your problem....
Old Dec 16, 2002 | 08:12 PM
yoshio006's Avatar
Default Re: Pulsing IDLE?!?!? (prelude1897)
got no check engine light. Thats also what is so confusing.
Old Dec 16, 2002 | 11:10 PM
DsITR's Avatar
has your check engine light ever worked??? w/that kind of issue I don't see why you wouldn't be throwing codes...
my friend just bought a teg w/the bulb removed started to have a bunch of issues...an we checked to see, guess what no bulb...scandalous car dealers..
Old Dec 17, 2002 | 06:29 AM
yoshio006's Avatar
Default Re: Pulsing IDLE?!?!? (dsludefosho)
my chech engine lights works. I have seen it come on before but not recently. Heh I can stall my car on purpose to see if it goes on. J/k. Doesnt it come on when I first start the car? Anyways the light does work and I still have no clue as to why my car is doing what its doing.
Old Dec 17, 2002 | 07:02 AM
hondalude9394's Avatar
I have the same problem except mine pulses when i leave it alone, but then when i try to go, it falls on it face like u said. Its at the shop right now hopefully they will figure out something. I will let u know if they do.
- I have had this problem for awhile now, and i have had no CEL.
Old Dec 17, 2002 | 07:55 AM
yoshio006's Avatar
Default Re: Pulsing IDLE?!?!? (hondalude9394)
sweet..let me know what happens. Im completly stumped and curiouse to see what the problem is
Old Dec 17, 2002 | 12:47 PM
yoshio006's Avatar
well this is what my car is doing. It idles fine but when I bring the rpm's up and hold them they pulse. It only does it between 2-4k after that the car holds with no pulsing. It still drives ilke 4 feet at a time and falls on its face. I cant find any visibel vacume leaks. Any ideas
Old Dec 17, 2002 | 05:22 PM
Well I had a hole in a gasket for my intake manifold, so he put a new one on, then I dynoed it. And it idles to lean. So now its time for a V-AFC, just gotta find a cheap one.
[Modified by hondalude9394, 6:23 PM 12/17/2002]
Old Dec 17, 2002 | 06:18 PM
yoshio006's Avatar
what gasket did you get replaced? was that your problem? Why would you be running lean now?
jeff gonzalez
10
Jun 27, 2019 10:16 AM
tunerboy90
Jul 29, 2008 07:46 PM
dystro
Jan 30, 2006 11:22 AM
DannyITR
Jul 21, 2004 05:10 PM
champwhiteitr
Mar 17, 2004 03:39 PM
