problem
Old Sep 26, 2001 | 07:46 PM
91LUDESI's Avatar
New User
Default problem
i got a 91 prelude si 2.1 i have a fuel pressure reg intake headers and exhaust. i start my car and if i blip my gas pedal it boggs out like as if it was to stall sometimes it does. i thought it was cause of my fuel filter changed it same ****. i think it is cause of the commando flow fuel pressure regulator i have it at stock psi still does it it also boggs out when iam in high rpm's. anybody have this problem or know what to do
Old Sep 27, 2001 | 06:30 AM
GraphiteAccord's Avatar
Default Re: problem (91LUDESI)
Try your stock FPR. It could be your command flow is flowing quite a bit more fuel, but at the same psi. what do your plugs look like? you may even be running lean high end.
Old Sep 27, 2001 | 08:57 AM
91LUDESI's Avatar
New User
Default Re: problem (GraphiteAccord)
NAH THEY ARE NORMAL A LITTLE BLACK BUT PRELUDES RUN HOT SO ITS NORMAL I HEARD IT CAN BE MY TEMPERATURE CONTROL I DONT KNOW WHAT IT IS. IAM GOING TO PUT THE STOCK FUEL PRESSURE REGULATOR ON. NOW I HAVE TO BUY ONE CAUSE U HAVE TO CUT THE STOCK ONE FOR THE COMMANDO FLOW. DO U KNOW IF A 98 ACCOROD FPR FITS
yywjsutherla
Honda CR-V & Element
Sep 13, 2017 12:38 PM
91tealhatch
Nov 3, 2008 07:10 AM
3.point.2
Dec 16, 2006 01:12 PM
C70Civic
Jan 4, 2004 08:48 AM
C70Civic
Jan 2, 2004 10:11 PM
