prelude motor mounts...the same?
Old May 4, 2003 | 11:41 AM
black_sh's Avatar
Default prelude motor mounts...the same?
does anyone know if the prelude rear motor mounts are the same for teh 4th gen and 5th gen? i need to get energy suspension bushings, but they don't make it for the 5th gen. any help would be appreciated
Old May 4, 2003 | 01:29 PM
satan_srv's Avatar
Default Re: prelude motor mounts...the same? (black_sh)
yeah they work fine.
Old May 4, 2003 | 03:02 PM
black_sh's Avatar
Default Re: prelude motor mounts...the same? (satan_srv)
so...i'll take that as meaning that they are the same?
Old May 4, 2003 | 03:18 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_sh &raquo;</TD></TR><TR><TD CLASS="quote">so...i'll take that as meaning that they are the same? </TD></TR></TABLE>
yes, some people talked about having to trim the back mount a little, not sure but it's might be because they did it with the engine in and probably couldn't wedge it in without trimming a little.
Modified by satan_srv at 7:53 PM 5/4/2003
Old May 4, 2003 | 03:40 PM
4bidden's Avatar
Has nothing to do with the motor being out or not. The bolt that secures the mount to the subframe will not go in straight due to the added width of the insert.
Old May 4, 2003 | 03:53 PM
satan_srv's Avatar
Default Re: prelude motor mounts...the same? (4bidden)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bidden &raquo;</TD></TR><TR><TD CLASS="quote">Has nothing to do with the motor being out or not. The bolt that secures the mount to the subframe will not go in straight due to the added width of the insert. </TD></TR></TABLE>
well there you go, is this for all gens? or just 5th?
Old May 4, 2003 | 09:04 PM
Casual Gcode1's Avatar
I got the two bolts in on the back of the mount but i cannot do anything to get the front one in the rear mount. Are you saying that if i trim some of the inserts off then it will go in because i have had just those two bolts in for like a month and a half. I hope that is the answer to my problem.
Old May 5, 2003 | 06:02 AM
black_sh's Avatar
Default Re: prelude motor mounts...the same? (Casual Gcode1)
ok....so if i buy the energy suspension inserts for the 4th gen model...could i fit them into all of the 5th gen motor mounts(sides and rear) or just rear? also, do i have to get the 4th gen motor mounts or what do i have to do?
Old May 5, 2003 | 07:15 AM
All they are are inserts for the torque positions which are the front of the motor and rear. There are no side inserts and they fit into your exsisting mounts.
Old May 5, 2003 | 07:17 AM
4bidden
Quote, originally posted by 4bidden »
Old May 5, 2003 | 07:44 AM
black_sh's Avatar
thanks for the help. you guys are awesome
Old May 5, 2003 | 08:37 PM
4bidden
Old May 8, 2003 | 06:40 PM
black_sh's Avatar
would i be able to use the 4th gen rear motor mount in a 5th gen to use the bushing inserts correctly?
Old May 8, 2003 | 07:29 PM
black_sh's Avatar
anyone?
Old May 8, 2003 | 07:32 PM
4bidden's Avatar
You cant get the middle bolt in? Refer to a picture in my write-up I did so I can tell what you are talking about.... http://members.***.net/4bidden/mount_install
Old May 8, 2003 | 07:49 PM
black_sh's Avatar
4bidden....should he be able to get the rear motor mount bolt in even if he is using 4th gen inserts on a 5th gen?
Old May 8, 2003 | 07:54 PM
4bidden's Avatar
Yes, the inserts have nothing to do with that middle hole.
vietdragontekx
Jul 5, 2006 09:22 PM
john d
Jul 3, 2006 05:40 AM
redmethods
Jan 19, 2004 02:18 PM
pakman27
Sep 3, 2003 11:14 AM
