Overheating
Old Dec 21, 2010 | 06:07 PM
  #26
1 Civic I's Avatar
Default Re: OVERHEATING
oh its hot. dont worry though its fixed. it was the vtec ground wire.. lets just say it was on another important ground wire the just messed it all up. all though for some reason when i turn my ac on it leaks and overheats sometimes after awhile but only one bar over. its leaking from the thermostat housing still. where the pipe connects to the thermostat. What you think?
Old Dec 21, 2010 | 06:40 PM
  #27
1GPlusSH's Avatar
you think you need to check that gasket and torque your bolts
Old Dec 22, 2010 | 09:33 PM
  #28
1 Civic I's Avatar
cmon guy that sounds like bad news... just got the engine installed lol...
Old Dec 23, 2010 | 03:43 AM
  #29
1GPlusSH's Avatar
on the thermostat...take the thermostat off and see how bad that gasket is. you may want to add some liquid gasket to it.
Old Dec 23, 2010 | 09:26 PM
  #30
1 Civic I's Avatar
maybe.. but i already replaced this oring btw not gasket. its the one that goes from the pipe to the thermostat housing.. maybe tho.. just weird how it seems to only be doing it when the ac goes on?
smh... and now my vtec aint working and starting bad.. check engine light.. computer maybe? i have my car wired differently. I used the h23 harness with the h22 internal dizzy,,, using my little trick and i dont know if its gone bad.. ughhh
Old Dec 24, 2010 | 03:38 AM
  #31
1GPlusSH's Avatar
i'd take it to someone that knows how to diagnose your issue. spend some money now before you ruin that motor.
Old Dec 24, 2010 | 06:21 AM
  #32
1 Civic I's Avatar
Yah i am after the holidays...
Old Dec 24, 2010 | 06:54 AM
  #33
godslayer's Avatar
Your car is the ground and the ground is the ground is the ground...
Crossing ground wires isn't like crossing the beams of a proton pack.
Old Dec 24, 2010 | 08:22 AM
  #34
m00nr0ck Si's Avatar
I went through all of this 2 years ago...replacing radiators,hoses,flushing,etc...and in the end it was a leaking headgasket....put a new OEM honda headgasket on along with honda headstuds and it runs like a new engine...not saying that this is the solution to yours but I would say there is a good chance...
Old Dec 24, 2010 | 03:09 PM
  #35
1 Civic I's Avatar
its not overheating anymore guys... just leaks from the housing.. It was a ground or it needed a good bleed. either way hasn't overheated in the last 3 days...
Everything looks fine as well.. no smoke. no oil in the radiator. no water in the oil...
if it is the head gasket. its very small...
Old Dec 28, 2010 | 06:26 AM
  #36
1GPlusSH's Avatar
Santa must have visited you
patoloco008
Aug 29, 2013 11:42 AM
nonvtec92
14
Nov 28, 2008 04:50 PM
jameskhan
Apr 10, 2008 08:09 AM
greasemonkee
Nov 24, 2006 01:22 PM
raene
Mar 1, 2003 05:06 PM
