Oil Light problems PLZ HELP!!
Old Dec 13, 2010 | 03:41 PM
carter64's Avatar
Icon3 Oil Light problems PLZ HELP!!
I have a f22a 1994 hond prelude and the other day a friend ran the front end in a ditch and the dash light went out, but came back on fine. The oil light started flickering a few days ago when the car warms up and then it comes on when my rpms drop, then it will stay on, then when i give it gas it blinks no stop till i cut my car off. No oil leak, plenty of oil just changed it 2 weeks ago. I cant firgure it out plz help me!!!! No real problems with it but i love this car and any problems bother the hell out of me.
Old Dec 13, 2010 | 03:46 PM
AyOhOndA's Avatar
Default Re: Oil Light problems PLZ HELP!!
Which dash light went out? All of them? Might have jerked a connection loose if he ditched it and the lights flickered around. Is the oil light the only one blinking and going on and off?
Old Dec 13, 2010 | 06:31 PM
godslayer's Avatar
What? See below:
Probably bent the oil pan.
It's not fitting to complain about reliability problems for a car you take absolute **** care of.
Old Dec 14, 2010 | 05:01 PM
carter64's Avatar
**** care of?? nah i love this car more than anything else, sad i know but **** idc. I take very good care of this car, it was **** when i got it
Old Dec 14, 2010 | 05:04 PM
carter64's Avatar
Yeah just the oil light now the others dont go out anymore, it only happens after the car warms up and then i come to a stop, then it will blink after. I dont really know how to check the connection because im am very new to car stuff
Old Dec 19, 2010 | 09:25 PM
carter64's Avatar
still no solution found, any help would be appreciated
Old Dec 20, 2010 | 12:24 AM
BlackCatt's Avatar
Check the connection at the oil pressure sender, not sure of the location
on a f22 but it is likely near the oil filter, either above it or below it.
Old Dec 20, 2010 | 04:10 AM
1GPlusSH's Avatar
oil pump or a sensor is my guess. your "friend" should pay a mechanic to check it out since you don't know what to look for.
Old Dec 20, 2010 | 04:13 AM
smokin rubber's Avatar
either you bent the pan restricting flow into the pickup or when you went into the ditch all the oil sloshed away from the pickup due to the angle of the car.
Old Dec 20, 2010 | 06:12 AM
vinuneuro's Avatar
If the sensor is ok you're going to ruin the engine if it's not already, by continuing to drive it. Inspect the oil pan, it's probably dented around the pickup like others have pointed out.
Old Dec 22, 2010 | 01:16 PM
carter64's Avatar
no oil pan is def not bent at all ive checked mutiple times and i will check near my oil filter later cuz it is in the back of my engine. Thanks for the help i never wouldve looked there
Also i just put a thin layer of plasti dip on my tail lights you can see all the lights fine is it it illegal???
ArkansasDave
Classic Hondas
Apr 23, 2011 04:23 PM
ADerks12
May 21, 2007 01:18 PM
dis
Mar 16, 2006 08:38 PM
spooncivic1
Mar 2, 2006 08:20 AM
BoostR41
Apr 7, 2005 08:44 PM
