OBDll workaround???
Old Jan 21, 2003 | 06:24 PM
sslude's Avatar
Default OBDll workaround???
i heard that the OBDll does not change anything. i heard that it is the same as the OBDl except it has 2 comp.s or something like that.
Old Jan 21, 2003 | 06:26 PM
satan_srv's Avatar
Default Re: OBDll workaround??? (sslude)
lol
http://www.ntpog.org/mods/fifth-afc/ecu.shtml
Old Jan 21, 2003 | 06:35 PM
sslude's Avatar
Default Re: OBDll workaround??? (satan_srv)
so it IS true, right? becuase i dont wanna go up to him and say stuff when i dont know what i am talking about and look stupid.
Old Jan 21, 2003 | 07:11 PM
ki11a8ee's Avatar
so what does this excatly do to ur car???
confused
Old Jan 21, 2003 | 07:24 PM
sslude's Avatar
Default Re: OBDll workaround??? (ki11a8ee)
OBDll is suppose to make your car work like an OBDl. and if you are wondering why, then click the link. i am just asking if this is really true, like a ard fact
Old Jan 21, 2003 | 08:07 PM
Ritteri's Avatar
Old Jan 21, 2003 | 09:00 PM
satan_srv's Avatar
Default Re: OBDll workaround??? (Ritteri)
Old Jan 21, 2003 | 10:01 PM
JG Luder's Avatar
um... wow. I just lost IQ points.
Keepin it simple: same computer, different program, more sensors.
Not two, not a little elf under your carpet... just an upgraded version all Hondas had to upgrade to in 96.
OBDII just has it's little fingers more into the way your motor acts.
This isn't exactly the scientific 100% correct way to describe it, but it's easiest to understand:
The ECU controls things like fuel curves etc.
OBDI had it's fingers in a little bit of the workings of the car.
OBDII has it's entire HAND in the workings of the car. It has preset standards that it thinks it should have to operate properly (like air intake, fuel, timing etc) and it "learns" your new mods after about a weeks worth of driving, and tries it's best to set things back to a stock level.
The OBDII workaround simply cuts the memory wire to the ECU. It doesn't have enough time to learn your new mods. It wakes up each morning in a whole new world.
It's AWESOME for things like, oh, TEST pipes... and it'll keep you from throwing a code.
Old Jan 22, 2003 | 07:16 AM
Justwakin's Avatar
Default Re: OBDll workaround??? (KMS Luder)
KMS is on the money.
with the OBDII...everytime you turn the car off it resets the ecu.
Old Jan 22, 2003 | 11:20 AM
DsITR's Avatar
his isn't exactly the scientific 100% correct way to describe it, but it's easiest to understand:.
D just noticed that sslude's title is blah LMAO ...I think that is the best way you could have described it, according to the posts above
I did not have a clue what the ? was until now..
to put it in even more simple terms...OBDII is more restrictive as far as mods are concerned, when compared w/OBDI
[Modified by dsludefosho, 1:22 PM 1/22/2003]
jonnyb227
Other Make Vehicles
Jul 20, 2009 08:25 AM
alpinefr3ak
Nov 14, 2007 10:23 AM
slowman
Dec 9, 2002 01:55 AM
NuGgEt
Jan 28, 2002 01:02 PM
