best cams for nitrous??
Old Apr 28, 2009 | 11:43 AM
ctr-ek's Avatar
Default best cams for nitrous??
alright heres my dilemma, im trying to figure out which cams would be best for me to use for my nitrous setup. i was thinking maybe pro 1's or pro 2's maybe someone can help me out heres what my setup consist of....
its a sleeved gsr block bored out to 83mm 11:1 CP pistons, pauter rods, serviced LS crank, gsr head with supertech springs and retainers, hytech rep headers, 3in. piping, edelbrock intake manifold with 75mm t/b and a 4fogger system
im looking to actually do a 75-100 shot single fogger out the hole and then use the 4fogger with a 200-250 shot.
if you guys have any useful info please throw it my way, thanks
Old Apr 28, 2009 | 03:48 PM
IceySC's Avatar
Default Re: best cams for nitrous??
i had skunk2 stage 1's on my nitrous setup and made great power .and my cp was 11:7
Old Apr 28, 2009 | 06:28 PM
ctr-ek's Avatar
anyone else?
Old Apr 28, 2009 | 07:55 PM
SilverEk3dr's Avatar
Was running endyn bumpsticks (very similar to jun3's, skunk2 stage 2). Was a gsr with b16 pistons (11.5 ish). Made 246 on a 100shot on a dyno that I know is notorious for reading low. Went 12's in a lightened integra
Old Apr 29, 2009 | 07:07 AM
IceySC's Avatar
i found my dyno sheet last night made 199.1 hp and 138.1tq allmotor on nitrous the car made 230.7hp and 188.4 tq thats with a zex kit 55 shot. not bad. you dont want to big of a cam for nitrous . it would be like blow by.
Old Apr 29, 2009 | 07:11 AM
ctr-ek's Avatar
so pro1's??
Old Apr 29, 2009 | 09:07 AM
IceySC's Avatar
what are the spec.s on them ?
Old Apr 29, 2009 | 10:03 AM
ctr-ek's Avatar
http://www.skunk2.com/installation/305-05-5140.pdf
http://www.skunk2.com/installation/305-05-5145.pdf
this is what i found
Old Apr 29, 2009 | 02:16 PM
ctr-ek's Avatar
Old Apr 29, 2009 | 03:10 PM
ghostofnyc's Avatar
Is your head ported? What edlebrock intake mani are you running? What fuel and engine management are you running
Old Apr 29, 2009 | 03:17 PM
ctr-ek's Avatar
no my head isnt ported yet im using a victor x mani and has for fuel i havent decided yet
Old Apr 29, 2009 | 04:07 PM
ghostofnyc's Avatar
If you are going to port the head I would run the pro 2's if not then the pro 1's. Also the Victor X is not the best choice for a mani for your setup its going to push your powerband up to around the 6k mark. I hope you plan on using a deticated fuel system for this N20 setup.
Old Apr 29, 2009 | 08:44 PM
bauergold's Avatar
+1, definitely needed for this big of a shot.
Old Apr 30, 2009 | 07:34 AM
IceySC's Avatar
pro 1's will work fine but they are right about the manifold its to big for your setup the skunk2 pro manifold would work great . you could sell the victor x and pickup the skunk 2 manifold and still have alittle money left.
Old Apr 30, 2009 | 08:16 AM
ctr-ek's Avatar
yea ghostfonyc explained the manifold situation to me. ima see if i can get rid of the manifold with the t/b cuz its a 75mm t/b which is probably no good for me either
Old Apr 30, 2009 | 11:43 AM
IceySC's Avatar
what i would do is sell the manifold and throttlebody and get a stock one and send it to max bore for $100. he'll port it out to 2mm bigger then an itr throttlebody and it comes with a life time warranty. you cant beat that. and pick up an hondadta manifold gasket and a p2p throttlebody gasket at the same time they are cheap $75 for both.or you could just get the p2p manifold gasket then he would cut you a better deal. you should be able to pickup all that stuff and still have a little money in your pocket after you sell the manifold and throttlebidy you have.
Old Apr 30, 2009 | 01:31 PM
ctr-ek's Avatar
im going to just trade one of my friends since he decided to do a big turbo setup and needs my manifold and I decided to do nitrous he has the skunk2 pro series mani im just gonna get it port matched for my head
Old Apr 30, 2009 | 02:28 PM
ghostofnyc's Avatar
smart man
Old Apr 30, 2009 | 05:54 PM
ctr-ek's Avatar
still need info on which cams to use
Old Apr 30, 2009 | 06:24 PM
ghostofnyc's Avatar
Old May 1, 2009 | 01:47 AM
ctr-ek's Avatar
thanks!
Old May 4, 2009 | 09:28 AM
ctr-ek's Avatar
what u guys think about coating the pistons?
Old May 4, 2009 | 06:34 PM
ctr-ek's Avatar
Old May 4, 2009 | 10:05 PM
IceySC's Avatar
dont need to.
Old May 5, 2009 | 07:26 AM
ghostofnyc's Avatar
not necessary but it helps if you gonna get them coated check with Tbone
